...for the Account dimension, I am trying to trigger creation of its associated element security cube (i.e. }ElementSecurity_Account) - however, the only way I can do this (from experience), is if I right click on the dimension, Select Security > Element Security Assignments, edit and save... then the security cube will be generated.
The problem with this method, is the dimension contains millions of elements, hence it freezes when trying to load the list of elements.
Is there a way to create the element security cube other than the manual right click?
Thanks!
Matt
P.S. I know there is a TI function for CellSecurity, but wasn't sure if there was one for ElementSecurity...
