Alternate ways to create an Element Security cube?
fleaster
Excel Version: XL2010
Post by fleaster »
Ok, I feel really dumb for asking this question, but here goes... :)
...for the Account dimension, I am trying to trigger creation of its associated element security cube (i.e. }ElementSecurity_Account) - however, the only way I can do this (from experience), is if I right click on the dimension, Select Security > Element Security Assignments, edit and save... then the security cube will be generated.
The problem with this method, is the dimension contains millions of elements, hence it freezes when trying to load the list of elements.
Is there a way to create the element security cube other than the manual right click? :)
Thanks!
Matt
P.S. I know there is a TI function for CellSecurity, but wasn't sure if there was one for ElementSecurity...
Re: Alternate ways to create an Element Security cube?
fleaster wrote: Is there a way to create the element security cube other than the manual right click? :)
If you use the ElementSecurityPut() function in a TI, and the }ElementSecurity_ cube doesn't already exist, the cube will be created. Just be aware that by default any elements / groups that you don't explicitly assign security to in this way will have a security value of WRITE, not NONE. (This makes sense, as effectively the users had write access before the security cube was created.) Of course, if you add new elements to the dimension after the security cube has been created in this way, the new elements will have a default value of NONE just as you would expect.
fleaster
Post by fleaster »
ok good idea.. thanks for the tip! :)
Just in case it wasn't obvious from Alan's post to create the element security cube with ElementSecurityPut via TI you do need to make sure that the function puts a value that isn't 'WRITE' e.g. ElementSecurityPut( 'READ', cDimTgt, vEle, vGrp ). As implicitly where there is no element security there is universal write access then if you do ElementSecurityPut( 'WRITE', cDimTgt, vEle, vGrp ) the server will interpret this as "nothing to change here" and not create the security cube.
Ajay
Version: 10.2.0, PA 2.0.9
Post by Ajay »
Hi Matt
When I know that I need a dimension that needs, say attributes and security, I normally add them when I create the dimension, see below...............million ways to skin a cat, and all that !!! But agree with the above
HTH
Ajay
# Purpose:
# This process creates a dimension
# Variables
csDim = 'DimensionYouWant' ;
csDimAttr = '}ElementAttributes_' | csDim ;
csDimSec = '}ElementSecurity_' | csDim ;
# Create dimension if it doesn't exist
IF ( DimensionExists ( csDim ) = 0 ) ;
	DimensionCreate ( csDim ) ;
	DimensionCreate ( csDimAttr ) ;
	DimensionCreate ( csDimSec ) ;
ENDIF;
Ajay wrote:Hi Matt
HTH
Ajay
[/quote]
Do you also create the cubes '}ElementAttributes_' | csDim and '}ElementSecurity_' | csDim ?
qml
Excel Version: 2007 - 2016
Post by qml »
Ajay wrote:When I know that I need a dimension that needs, say attributes and security, I normally add them when I create the dimension, see below...............million ways to skin a cat, and all that !!! But agree with the above
Ajay, the '}ElementSecurity_YOURDIM' dimension makes no sense - there is no possible use for it. The '}ElementAttributes_YOURDIM' dim is of little use unless you also create the '}ElementAttributes_YOURDIM' cube - both of which get created when you do AttrInsert, so not much point in that either.
What would make sense is this:
IF( CubeExists( '}ElementSecurity_YOURDIM' ) = 0 );
	CubeCreate(
		'}ElementSecurity_YOURDIM',
		'YOURDIM',
		'}Groups'
ENDIF;
A security cube created in this way works fine and TM1 understands that it's a control cube, so this is a usable alternative to doing a single ElementSecurityPut.
Kamil Arendt
fleaster
Post by fleaster »
thanks all for the feedback!
Ajay wrote:Hi Matt
HTH
Ajay
Ajay, I have to concur with the others - as the } cubes are system generated, it's generally better to let TM1 create these itself. The trick is finding the right trigger that will cause it to be generated e.g. "AttrInsert" to generate the attributes cube, "ElementSecurityPut" to generate the element security cube etc
