Dimension Editor Hangs on when few shortcuts used on 10.2.2
sankeerthv
OLAP Product: Cognos EP 8.4, 10.1 and TM1 10
Version: Tm1 10.1.1 10.2
Excel Version: MS Office 2007
Post by sankeerthv »
Hello All,
Hope every one is doing to there best.
We are in to TM1 10.2.2 Fp1 family from 10.1.1.
Installed the TM1 10.2.2 on W 2008 R2 Enterprise edition 64 bit. Single server installation.
Things are working fine. But except Dimension and subset editor hangs with white screen and popups with close options as below attachments.
So required your help in solving the same. Please read the below problem more in detail.
1. When you edit the dimension editor by click on the dimension name in Architect. And when you use Windows+up arrow or just up arrow or down arrow. Immediately the architect goes in to White screen. When ever you press the mouse then it shows the close window popup as shown in attachments.
2. same problem repeats with subset editor.Click on the subset and enter opens the new subset editor.But when you use shortcuts like Windows+up arrow or just up arrow or down arrow Immediately the architect goes in to White screen. When ever you press the mouse then it shows the close window popup as shown in attachments.
All the windows like cube,view and process are working fine with all short cuts.
Now need your help and to confirm the 100% successful installation. I need to sort out the above error.
Awaiting very eagerly for the same.
Dimension editor crashes
Tm1 10.2.2.png (17.7 KiB) Viewed 7084 times
subset editor crashes
image002 (1).png (13.98 KiB) Viewed 7084 times
pandinus
OLAP Product: TM1, Cognos Express
Re: Dimension Editor Hangs on when few shortcuts used on 10.
Post by pandinus »
Same result here on Windows Server 2008 R2.
It works fine on Windows 8.1 though..
BrianL
Version: 9.5.2 10.1 10.2 PA2
Post by BrianL »
Doesn't look like architect is officially supported on Windows Server 2008 R2.
http://www-969.ibm.com/software/reports ... 37468919#!
sankeerthv
Thanks a lot for your quick reply. the link provided will be very helpful as an artifact to discuss with Higher Managers.
Have a great day ahead..
kangkc
Version: 2.x
Excel Version: 36x
Post by kangkc »
Actually this problem is not due to Windows 2008. It happens on WIn7 as well. Just get hit with this issue. Should be raising a PMR soon.
AniketTambavekar
OLAP Product: Tm1 Cognos
Version: TM1 10.2.2
Excel Version: Excel 2010
Post by AniketTambavekar »
Me and Sankeerth have found an workaround for the issue raised.
Use the Architect (TM1a.exe) from bin folder after the installation. Architect from this folder is working fine and Advance Rule Editor can be used from this application.
By default the Architect points to bin64 folder in 64 bit installation. So create a short cut or pin to start menu from bin folder to use TM1a.exe every time.
Do check and revert back if you need any help.
