Error on client creation architect 10.2
ARNOJ
Excel Version: 2010 SP1
Post by ARNOJ »
Morning
For my preivous client, I had to use IBM Cognos Express and then my current client is using IBM Cognos TM1 10.2. I have install the latest version with the latest pack released in oct 2014
However when I open architect (IBM Cognos TM1 10.2) and I go to client/groups and then add client, I have this pop up windows which tell me error 404
Even if it is French it is mainly say that the server is not avalaible
I have try to install the same 10.2 version on a serveur and I have no message.
Before redoing all my PC does anyone have a suggestion ?
Arno
erreur TM1.jpg (61.4 KiB) Viewed 3232 times
Please note that English is not my native language.
BrianL
Version: 9.5.2 10.1 10.2 PA2
Re: Error on client creation architect 10.2
Post by BrianL »
Are you using CAM? If so, check your CAM server settings.
If not, either edit your tm1p.ini file to disable CAM or just delete the file. Architect should be able to recreate it no problems at all.
ARNOJ
Post by ARNOJ »
Thanks you ! Save me a lot of time
