We have a process that connects Cognos package connector, and we get error while executing this process. There are four hierarchies and only one hierarchy stopped executing. We couldn't identify the error cause either from BW or TM1.
I have attached all the details with error description. Can any one help me out to identify the issue?
I have tried out all the steps mentioned to rectify the error TR0168. But no use.. still get the error.
KKMK
CCognosDimension::BuildDataSource Exception: (TR0168)
- Version: 10.2
- Excel Version: 2013
- Select Hierarchies.docx
- (63.78 KiB) Downloaded 347 times
- Excel Version: Excel 2007
Re: CCognosDimension::BuildDataSource Exception: (TR0168)
Did you happen to modify your SAP Info Query and changed its restrictions but did not republish the Framework Manager package?
You can enable logging in the query stack. In the TM1 Package Connector directory on the TM1 Server, edit configuration/qfs_config.xml.
Change to: <logCommands value="2"/>
In the logs/ folder look for OQP log files and see if there are more error details.
