TM1 10.2 control dimension write access
tposepny
OLAP Product: IBM Cognos Express
Version: 10.2.1.1
Post by tposepny »
I came across a problem with Control Dimension. I have two separate approval applications. The are using completely different cubes. I want both applications to have the same approval hierarchy and control dimension. However, when I try to set the WRITE access in control dimension to the same element, I get following error:
"The control dimension element <element_name> is a writable element of another application"
I thought, this is only problem for two applications sharing the same cube. Why can't I write to the same dimension element in completely different cubes??
Thanks for any help.
uchow10
Re: TM1 10.2 control dimension write access
Post by uchow10 »
Is your application set to use Element Security or Cell Security? I believe that is something you can set when deploying your application. That may have something to do with it....
