TM1 TI: string date validation
vovanenok
Version: 2.0.9
Post by vovanenok »
In my cube I have dates in format "yyyy-mm-dd". I need to implement data validation so my TI process catches invalid dates (empty and all those don't match the pattern "yyyy-mm-dd").
If I try to use DayNo() function, the process fails when encounters the first invalid date. So it seems I need to use multiple SUBSTs and validate separate patterns. Does anyone have anything on this matter?
Thanks in advance!
TeamOne Google Sheets add-on for IBM Planning Analytics
Let's connect on LinkedIn
Re: TM1 TI: string date validation
Why would you not want to store dates in TM1 as serial numbers? Everything is so much easier when you do so. To display the serial number as yyyy-mm-dd in TM1 you simply format it so show that. Behind the scenes the data is just a number. If the dates are serial numbers and formatted as you want, this will stop a lot of invalidate dates from ever getting in to the cube in the first place.
vovanenok
Version: 2.0.9
Post by vovanenok »
Thanks Tomok
I was thinking about this, but haven't learned that question enough. So this time I think I can make the decision towards numbers.
Just one question. I noticed that if I set "yyyy-mm-dd" format, it displays that accordingly, but when I double click the cell to edit it in a cube viewer, the format changes to the TM1 server regional settings (in my case: "mm/dd/yyyy"). Can I somehow prevent it?
vovanenok
Version: 2.0.9
Post by vovanenok »
Also I'm not able to copy/paste values
vovanenok
Version: 2.0.9
Post by vovanenok »
vovanenok wrote:Also I'm not able to copy/paste values
Just realized that the reason is in format difference: looks like it's getting confused with server's and my local regional settings
Does Architect use local regional settings?
On attached screenshot you can see how the format changes when I double click the cell
It's worth looking into other avenues as you are but in the event you go back to just wanting to validate the string input; the below should work (might require a few tweaks as I haven't tested it.)
If ( Long ( sDate ) <> 10 );
	ItemReject ( 'Invalid Date Character Encountered: "' | sDate |'"' );
Else;
	iCount = 1;
	iMax = 10;
	While ( iCount <= iMax );
		sString = Subst ( sDate, iCount, 1 );
		If ( ( iCount = 5 ) % ( iCount = 8 ) );
			If ( sString @<> '-' );
			EndIf;
		ElseIf ( ( Code ( sString, 1 ) < 48 ) % ( Code ( sString, 1 ) > 57 ));
		EndIf;
		iCount = iCount + 1;
	End;
EndIf;
sYear = Subst ( sDate, 1, 4 );
sMonth = Subst ( sDate, 6, 2 );
sDay = Subst ( sDate, 9, 2 );
nYear = StringToNumber ( sYear );
nMonth = StringToNumber ( sMonth );
nDay = StringToNumber ( sDay );
If ( ( nMonth < 1 ) % ( nMonth > 12 ) );
	ItemReject ( 'Invalide Month: "' | sMonth | '"' );
ElseIf ( nMonth = 2 );
	nDiv4 = nYear \ 4;
	nDiv100 = nYear \ 100;
	nDiv400 = nYear \ 400;
	If ( Round ( nDiv4 ) = nDiv4 );
		If ( Round ( nDiv100 ) = nDiv100 );
			If ( Round ( nDiv400 ) = nDiv400 );
				sLeapYear = 'Yes';
			Else;
				sLeapYear = 'No';
			EndIf;
		Else;
			sLeapYear = 'Yes';
		EndIf;
	Else;
		sLeapYear = 'No';
	EndIf;
	If ( ( sLeapYear @= 'Yes' ) & ( nDay > 29 ) );
		ItemReject ( 'Invalid Day: "' | sDay | '" of year: "' | sYear | '"' );
	ElseIf ( ( sLeapYear @= 'No' ) & ( nDay > 28 ) );
	EndIf;
ElseIf ( ( nMonth = 4 ) % ( nMonth = 6 ) % ( nMonth = 9 ) % ( nMonth = 11 ) );
	If ( nDay > 30 );
	EndIf;
ElseIf ( nDay > 31 );
EndIf;
vovanenok
Version: 2.0.9
Post by vovanenok »
Thanks declanr for useful code. it will be definitely handy!
vovanenok
Version: 2.0.9
Post by vovanenok »
I would like to bump this topic again as my last question didn't get any answer.
I'm trying to use number with custom format (yyyy-mm-dd), but when I double-click the cell to edit it in Architect, the format changes to the server local one (mm/dd/yyyy). However that format doesn't work when I edit the cell. It expects my local machine date format.
I'm experimenting with Jan 25, 2013 so I see where my year / month / day are. Please see my actions on the screen shot below.
Also it doesn't allow me to copy paste values . I'm able to copy/paste values only after changing element format to my local one.
Did anyone encounter such issue?
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Post by Andy Key »
No solution to your problem, as far as I am aware, Server Explorer has always behaved this way.
Andy Key
vovanenok
Version: 2.0.9
Post by vovanenok »
Andy thanks for the confirmation.
