Decimal numeric parameter?
macsir
Version: PAL 2.0.9
Post by macsir »
maybe it is a another stupid question :oops:
when it is a numeric parameter in TI, in the parameter window, it is showing correctly. But when to run it, it only shows the integer part of this number?
Am I missing something here?
macsir
Version: PAL 2.0.9
Re: Decimal numeric parameter?
Post by macsir »
When to run it
hyunjia
Version: 2010
Excel Version: Excel 2010
Post by hyunjia »
Could you state the TM1 version that you are using ? I have never encoutered this problem , and it's really shock if that's a bug . :o
macsir
Version: PAL 2.0.9
Post by macsir »
hyunjia wrote:Could you state the TM1 version that you are using ? I have never encoutered this problem , and it's really shock if that's a bug . :o
Yeah, I thought it should not be a problem but I tried many times. It does ignore the decimal part of that parameter.
Thanks, the server's version is 10.1.00100.24600
hyunjia
Version: 2010
Post by hyunjia »
Confirm the same happened in 10.1.1 SP2 , :!: it certaily is a bug
macsir
Version: PAL 2.0.9
Post by macsir »
hyunjia wrote:Confirm the same happened in 10.1.1 SP2 , :!: it certaily is a bug
Thanks for that. Anyone else can test on other versions?
Same thing in both 9.5.2 and 10.2. The decimal value is saved in the .pro file, but when TI loads the prompt dialog it truncates that to the integer value.
I've got around this previously by having 2 parameters (the integer and the decimal), it was being ran from tm1 web so users typed into 1 box then hidden cells split it out. If you want to run directly that would feel cumbersome though.
Could enter the parameter as string then convert it to a number but then you run the risk of people typing stupid things.
macsir
Version: PAL 2.0.9
Post by macsir »
Yeah, the only way I can do is to use string and conversion.
