Relational Drillthrough from Cognos Insight does not work
Pim van Putten
Post by Pim van Putten »
Dear All,
I have a TM1 model in TM1 10.2 FP1 with a relational drillthrough that perfectly works from all interfaces (Cube View, Excel DBRW, TM1 Web) but NOT from Cognos Insight. I can click on the correct drill string via Get Detail, but nothing happens...
I can see in the message log that the drillprocess was correctly executed but the RETURNSQLTABLEHANDLE did not result in the usual popup with the relational data.
Is this a bug? The feature seems to be present as I can click on the correct drill string...
Screenshot of the Relational Drill option in Cognos Insight
Sincerely,
Pim van Putten
r0b1979
OLAP Product: TM1, SQL Server
Version: 9.5.2
Excel Version: 2007 2010
Re: Relational Drillthrough from Cognos Insight does not wor
Post by r0b1979 »
Hi Pim,
I just encountered the exact same problem, so I was wondering if you by any chance found a cause or solution for this issue?
Rob Elshout
dr.nybble
Excel Version: Excel 2007
Post by dr.nybble »
Relational drill through is not yet supported in Cognos Insight / TM1 Performance Modeler.
It requires client-side orchestration that is not there yet.
r0b1979
Version: 9.5.2
Post by r0b1979 »
I see, thanks for clearing that up. Will look for other options for now.
Rob
