Hi!
We're planning to implement CX and I'd like to get full list of limitations it has... I know 3 only:
1. 100 users
2. single-box having 32 core maximum
3. no connectors to ERP
I've heard 2 more:
1. 32 Gb RAM Limit - is it true?
2. Single application - thus if we need (for any reason) separate applications for budgeting and forecasting, CX doesn't suit our purposes. Is it correct?
Thanks in advance!
Vasily
Cognos Express Limitations
Re: Cognos Express Limitations
vdodonov wrote:Hi!
1. 100 users
I've heard 2 more:
Thanks in advance!
Vasily
First thing of note is that what used to just be 100 users is now split to 50 read/write users and 50 read only (I believe.)
The 2 more that you've heard:
1/ 32 Gb RAM Limit - Not one I've heard before and I seriously hope this isn't true - can anyone comment?
2/ Single Application - CX just allows 1 service; you can however buy multiple CX licences to allow multiple services (and a half price or reduced price at least option for a dev box)
vdodonov
- OLAP Product: SSAS
- Version: 2012
- Excel Version: 2013
Hi Rodger!declanr wrote:vdodonov wrote:Hi!
1. 100 users
I've heard 2 more:
Thanks in advance!
Vasily
Thank you for your reply!
To clarify "CX just allows 1 service": does it mean I can run only one CX application (set of linked models)? Or I can create number of independant sets having their independant data and rules, all of them are launched under single system service?
I don't know of any memory limitation for CX and don't believe this to be true.vdodonov wrote:To clarify "CX just allows 1 service": does it mean I can run only one CX application (set of linked models)? Or I can create number of independant sets having their independant data and rules, all of them are launched under single system service?
You are limited to a single TM1 server instance. You could have as many cubes, models and applications running within this service as you like.
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
The licensing rules have changed with the release of Cognos Express 10.2.vdodonov wrote:A
1. 100 users
B
1) Max 100 users but, within that, a maximum of 50 Performance Manager users
2) Now limited to 560 PVU's (probably 8 cores , ie 2 x Quad core processors)
3)t doesn't have the Cognos SAP package connector but that is not very good anyway. Most installs of Cognos Express (like TM1) include connections to ERP systems
B
1) Not true and never has been
2) More complicated. I believe you can run multiple instances but a) you need a licence for each instance and b) they cannot be connected using replication. Btw separate applications could live in the same CX instance.
