TM1 Web 10.2 No Username displayed
bunchukokoy
- Version: 10.2.2.x
Hi Folks,
Just want to ask if this is an overall issue or if it is just me who encounters this.
We just installed TM1 10.2 and configured it to use Cognos Security. But it does not seem to display my username when I connect.
This is single sign-on.
See image below.
Thanks.
Bunch
See image below.
Thanks.
Bunch
- TM1 Web 10.2 No UserName.png (105.11 KiB) Viewed 17065 times
tm1novice
- Version: 10.1
- Excel Version: 2003
Re: TM1 Web 10.2 No Username displayed
It seems there are some issue with tm1 10.2 web sso..
could be due to that.
Thanks.
Thanks.
bunchukokoy
- Version: 10.2.2.x
Do you also encounter this Sir?
ruchika512
- OLAP Product: Tm1
- Version: 10.2
We are also facing the same issue..please let me know if anyone of you have found the solution
bunchukokoy
- Version: 10.2.2.x
My team hasn't taken the chance to directly raise a PMR for this.
manoj928
- Version: 10.2.1
Facing the same issue with TM1 10.2.1. installation.
Please let me know steps if someone is resolved the issue.
bunchukokoy
- Version: 10.2.2.x
Hi Folks.
I raised a PMR on this. THis is the rep's reply.
- Capture.JPG (35.06 KiB) Viewed 15842 times
nick_leeson
- OLAP Product: TM1 9x, BPC, Hyperion, HANA
- Version: TM1 10
- Excel Version: Excel 2003 - 2010
Can confirm this is fixed in TM1 10.2.2 also issue does not arise with CAM Security enabled.
stingo
- Version: 9.1 onwards
- Excel Version: client dependant
10.2.2 didn't solve it for us..nick_leeson wrote:Can confirm this is fixed in TM1 10.2.2 also issue does not arise with CAM Security enabled.
Anyone has idea in how to fix it?
Gabor
I just rechecked TM1 10.2 FP2 IF1 and TM1 10.2.2 FP2.
It worked for both versions and for native and Windows authentication in IE8 + IE9 (IntegratedSecurityMode=2).
Did you apply the latest Fixes?
stingo
Yep,Gabor wrote:I just rechecked TM1 10.2 FP2 IF1 and TM1 10.2.2 FP2.
integratedsecurityMode = 5
gopigarapati
- OLAP Product: COGNOS
- Version: 9.5
Hi Guys,
Username issue will be resolved in TM1 10.2.2 FP3
Gopi
Gopi
AniketTambavekar
- OLAP Product: Tm1 Cognos
- Version: TM1 10.2.2
- Excel Version: Excel 2010
Fix pack 3 solve the user name issue but if you are using perspective you will face issue with fix pack 3. Also cafe with security mode 5 is not working with fix pack 3
