Need some urgent help in TM1 Perspectives:
Can I connect to different TM1 servers in different excel tabs/sheets on the same excel workbook. If yes, how ?
Can I connect to different TM1 cubes in different excel tabs/sheets on the same excel workbook. If yes, how ?
Can I connect to different 2 TM1 servers/cubes in 2 different open excel workbooks and analyse data. If yes, how ?
Can I connect a TM1 cube in same spreadsheet that has data from other sources like HFM (Smart View), Bloomberg etc. If yes, how ?
I am using Excel 2010 and TM1 10.1 Perspectives.
Any help is greatly appreciated.
Many thanks
jyotish84
Connect to different TM1 servers in different excel tabs
Re: Connect to different TM1 servers in different excel tabs
By consulting the Reference Guide (a link to which can also be found in the FAQ Post) on the arguments to a DBRW Excel function.jyotish84 wrote:Need some urgent help in TM1 Perspectives:
Through the same method.jyotish84 wrote:Can I connect to different TM1 cubes in different excel tabs/sheets on the same excel workbook. If yes, how ?
Also through the same method.jyotish84 wrote:Can I connect to different 2 TM1 servers/cubes in 2 different open excel workbooks and analyse data. If yes, how ?
By searching the documentation for the expression "Slices" (which will also refer to the aforementioned DBRW formulas), or "Active Forms".jyotish84 wrote:Can I connect a TM1 cube in same spreadsheet that has data from other sources like HFM (Smart View), Bloomberg etc. If yes, how ?
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
As Alan has pointed out the answer to all of your questions is "yes" using basic TM1 functionality.jyotish84 wrote:....Can I connect a TM1 cube in same spreadsheet that has data from other sources like HFM (Smart View), Bloomberg etc. If yes, how ?
However just one point on your last question. If you use Excel with more than one add-in (TM1, HFM, Cartesis, Mokum etc) there may be some unexpected interactions.
erik664
- Version: 10.1.1
Alan, could you elaborate a little bit on your answer? How does the DBRW function know which server to look at? Can you put 'server:cube' for the first argument in the function, and be connected to both servers at the same time?Alan Kirk wrote:By consulting the Reference Guide (a link to which can also be found in the FAQ Post) on the arguments to a DBRW Excel function.jyotish84 wrote:Need some urgent help in TM1 Perspectives:
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Third paragraph of parent topic Worksheet Function Overview
erik664
- Version: 10.1.1
OK thanks, that's what I thought.
