Exponential Problem with Natural Consolidation
conray
Version: 9.5.2
Excel Version: Excel 2010
Post by conray »
Whats wrong with TM1 displaying values like (0,000000000000)?
I have a natural consolidation [CD Amt], calculated using [Std Amt] - [Act Amt].
By calculating it manually, i get a value of 0.
But the natural consolidation gives a (0,0000000000) value as shown in the attachment.
I have checked that there is no rounding issues and the values added up indeed is 0.
May i know what else could be the problem here?
Natural Consolidation Snapshot.xlsx
Excel file with snapshot data
(9.39 KiB) Downloaded 1074 times
Cubeview screenshot
Cubeview screenshot
Natural Consolidation with exponential.gif (44.02 KiB) Viewed 21407 times
Server OS: Windows Server 2008 R2 (64-bit)
TM1: v9.5.2 FP1
MS Office: Microsoft Excel 2003, 2010
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Re: Exponential Problem with Natural Consolidation
Post by ioscat »
cgaunt
Version: 9.0 SP3 9.5.1 10.1.1
Excel Version: excel 2010 2007 2003
Post by cgaunt »
Whilst I agree with Isocat that zero is not always zero, you should be able to control this affect in the formatting properties for the element in question.
ioscat
Post by ioscat »
And you should be very careful in using this non-zero values
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
For those that don't have access to the IBM APAR system the link ioscat includes has this to say
Calculations may result in a very small number, but not zero. If this value is used as the denominator with the 'save divide' operator "\", the division will be done resulting in a very large number, instead of treating the very small calculated number as zero.
An example of this is when you calculate the reciprocal of one minus ten tenths :-
1 \ ( 1 - ( 0.1 + 0.1 + 0.1 + 0.1 + 0.1 + 0.1 + 0.1 + 0.1 + 0.1 + 0.1 ) )
which gives 9007199254740900 and not 0.
Like ioscat said, you need to be careful.
rmackenzie
Post by rmackenzie »
Duncan P wrote:An example of this is when you calculate the reciprocal of one minus ten tenths :-
Duncan, that's interesting - if you substitute these rules then you get the correct answer of 0 per usage of 'safe divide':
1 \ ( 1 - ( 0.5 + 0.5 ) );
1 \ ( 1 - ( 0.25 + 0.25 + 0.25 + 0.25 ) );
1 \ ( 1 - ( 0.2 + 0.2 + 0.2 + 0.2 + 0.2 ) );
1 \ ( 1 - ( 0.125 + 0.125 + 0.125 + 0.125 + 0.125 + 0.125 + 0.125 + 0.125 ) );
But then try this which gives -4503599627370400:
1 \ ( 1 - ( 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05 + 0.05) );
What's up with tenths and twentieths that works fine with halves, quarters, fifths and eighths? Looks like some sort of 'issue exists where denominator is 10 or greater' type of issue, perhaps?
This strikes me as a bug, wouldn't you agree? Plenty of customers that I've worked with think this problem should go away.
Robin Mackenzie
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Post by Andy Key »
I would go for it being a limitation of IEEE-754 and the conversion of decimal to binary rather than a bug.
Do the same calculations (switching the \ to /) in Excel and you'll get the same results.
Now try doing the same with 64ths i.e. a number that can be represented in a precise manner in both decimal and binary (and is short enough to fit in to IEEE-754)
1 \ ( 1 - ( 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625 + 0.015625  + 0.015625 + 0.015625 + 0.015625 + 0.015625 ) )
in Excel you get a #Div/0! error and you get a full fat zero in TM1.
Andy Key
rmackenzie
Andy Key wrote:I would go for it being a limitation of IEEE-754 and the conversion of decimal to binary rather than a bug.
Seems to work ok on the calculator on the Windows desktop ;)
Seriously, I've seen TM1 give some flakey rounding errors on standard consolidations. When the balance sheet stops balancing, it becomes a problem for people for whom an explanation involving IEEE-754 just doesn't cut it. On that point, I'm familiar with some of the issues in binary floating point arithmetic but are we saying that there's no solution, or advance, on a problem that's inherent to a standard dating back to, what, 1985??
Robin Mackenzie
Duncan P
Post by Duncan P »
The problem is that the only way to get the speed is to use a representation on which the standard arithmetic operations can be done in hardware. IEEE754-2008 defines a number of decimal floating point representations but they are only supported in a small range of hardware (e.g. IBM Power6 and z9) and not on the standard Intel stuff. Hence we are stuck with the problems of rounding recurring binary representations of 1/5.
head_is_spinning :?
rmackenzie
Hey Duncan, thanks for the response - always welcome and appreciated. Just to play devil's advocate for a moment - wouldn't it be an interesting avenue to explore for TM1 to offer the same 'Precision as displayed' option that is referred to in this Microsoft support note? That's kind of what the OP was referring to in the third post of the thread and not entirely worlds apart from the existing SpreadingPrecision parameter available today in the tm1s.cfg ??
Robin Mackenzie
rmackenzie
lotsaram wrote:head_is_spinning :?
She'll be right ;)
Robin Mackenzie
conray
Version: 9.5.2
Post by conray »
So in summary, it is not possible to get a zero, unless using the "safe divide" method in the rule itself?
TM1: v9.5.2 FP1
ioscat
Post by ioscat »
Possibly yes and possibly no
Depends on
conray
Version: 9.5.2
Post by conray »
ioscat wrote:Possibly yes and possibly no
Depends on
depends on what?
It really is annoying to get something like this with only 2 decimal point involve:
Data
Data
ScreenHunter_04 Jun. 12 12.38.gif (10.96 KiB) Viewed 21143 times
look at all the (0.00)...
TM1: v9.5.2 FP1
rmackenzie
conray wrote:So in summary, it is not possible to get a zero, unless using the "safe divide" method in the rule itself?
No, the safe divide is no guarantee of getting absolute zero. The summary of the problem is that human numbering system (decimal) and computer numbering system (binary) don't always place nicely. Sometimes there are extremely small rounding errors meaning that the zero value is actually an extremely small number. This leads to your zero suppression problem. Maybe what we need is some sort of config parameter like:
ResolveToNullAtNthDecimalPlace=2
Robin Mackenzie
Tilo
Post by Tilo »
IBM states that this would be fixed in TM1 10.2 but it is not entirely if even or IBM means a Version above 10.2.0.
Create a formula as follows:
['a'] = N: ['b'];
where values for 'a' are entered directly and afterwards there is plain consolidation.
Then put 'a' and 'b' into a consolidation 'c'
where 'a' has the weight 1 and
b has the weight -1
then very often the result is c<>0 (e.g. 0,000000000000019387).
(at least in 10.2.0 and with our model).
This causes zero suppression Problems, calculation Problems (especially when using multiplication or backslash division, overfeeding
This does not happen (in our model) if you can create 'b' as consolidation of 'a' with the weight 1.
paulsimon
Version: PA 2.0.5
Post by paulsimon »
There is a TM1 Rule function ROUNDP
Won't that do what you need?
If all else fails use something like IF( ABS( [ cell ref ] ) < 0.0001 , 0 , [cell ref] )
tm1ist
OLAP Product: TM1 + BI
Version: 10.2 10.2.2 + 10.2.1 10.2.2
Excel Version: 2010 32 bit
Post by tm1ist »
When using a binary representation for numbers, it is expected to have very slight variations in numbers. It is because we use the decimal system and the binary system cannot represent all of the decimal numbers. It is vice versa, decimal numbers cannot represent some numbers in different bases as well. For instance, 1/3 is 0.33333333...33(which is never ending) in decimal system and when you multiply that 0.3333....33 with 3, you cannot get exactly 1. Long story short, as others explained, it is due to binary number system.
For financial applications, it is suggested to use decimal system because our monetary system is decimal and we don't have amounts like 1/3 USD which decimal system cannot represent. However, computer interpretation of decimal numbers takes longer time and memory, because the computer hardware works with 0 and 1(which is binary). This is not the case just for TM1 but also for any other software. In a programming language, when you compare the performance of a code piece when you use variable type double(which stores numbers as binary representation) or variable type decimal(stores as decimal representation), you will see that it will be faster when use variable type double. However, with double type you will have number precision issues like you do now with TM1. Also note that this precision issue is not just about 0 but for any number that is derived from some calculations of some noninteger values.
Therefore, what TM1 does is sacrificing monetary(base 10) number precision for faster performance. And, it gives you the chance to use a rounding function when you require the numbers to be exactly zero.
And the reason why 0.5, 0.25 etc can be represented in binary and 0.1, 0.2 cannot is about the exponents of 2. 2 exponent -1 is 1/2(0.5), 2 exponent -2 is 1/4(0.25) etc.
