I tried to explain what I need in many ways.
I hope It wasn't useless attempts.
So Could anybody gives ideas?
MDX query for filter
- OLAP Product: PAL
- Version: 2.0.9
- Version: 9.4 9.5.1
- Excel Version: 2003 - 2007
Re: MDX query for filter
Hi EP_explorer,
As I said in some posts before, you have to use INSTR function (which is not documented so it can be not supported in further version)
That will give you something like that:
Function "FilterbyPattern" doesn't work for cube or alias values indeed.EP_explorer wrote:Function Filter with "*" doesn't work - return empty selection
Apparently it is trying to find string "*" but not any elements as in FilterbyPattern
{FILTER(
TM1FILTERBYLEVEL(
{TM1SUBSETALL( [Time Monthly] )}, 0
, INSTR( [Time Monthly].CurrentMember.Name , [System Information].([System Information Measures].[FilterVal], [System Information Values].[Value] ) > 0 )
- OLAP Product: PAL
- Version: 2.0.9
Thank you a lot. It works - except one little thing.
If there are in Cube 1 in list are values
Region
1 Region1
2 Region2
3 Region11
4 Region3
and in Cube 2 user chooses Region1
it shows
Region
1 Region1
3 Region11
of course it is better than nothing but may be ways exists to solve the problem
Region
1 Region1
2 Region2
3 Region11
4 Region3
it shows
Region
1 Region1
3 Region11
I am not sure to know what you want but if it is to let users choosing to use or not wildcard search,
the only solution I have in mind is to add an extra indicator and some basic condition in your filter.
{FILTER(
TM1FILTERBYLEVEL(
[System Information].([System Information Measures].[FilterVal], [System Information Values].[WildCard]) = "T"
AND
OR
[System Information].([System Information Measures].[FilterVal], [System Information Values].[WildCard]) = "F"
AND
[Time Monthly].CurrentMember.Name = [System Information].([System Information Measures].[FilterVal], [System Information Values].[Value] )
- OLAP Product: PAL
- Version: 2.0.9
Thank you - your last reply was helpful
I did what I wanted
I did what I wanted
