OLE for OLAP TM1 missing
clubjoker
OLAP Product: IBM Cognos TM1
Version: 9.5
Post by clubjoker »
Hello everybody,
Ole for OLAP driver in my Architect is missing for selecting in TI-Process. I thought that i could reinstall the TM1 Client Components but don't know how. Are there any suggestions of how i can reinstall it?
Re: OLE for OLAP TM1 missing
clubjoker wrote:Hello everybody,
Right-click on the Setup.exe file from the installation package and choose Run as Administrator.
clubjoker
Version: 9.5
Post by clubjoker »
I have only install.exe in my installation folder!?!
cgaunt
Version: 9.0 SP3 9.5.1 10.1.1
Excel Version: excel 2010 2007 2003
Post by cgaunt »
In the event that the suggestion form Tomok yields n result, run the set up process on the server as usual, when you are asked to select the components, make sure you select the client components. It feels a little alien to have the client on the database server if you have only local clients, or citrix clients, but for this OLE DB component, it is required.
clubjoker
Version: 9.5
Post by clubjoker »
we have ibm cognos express 9.5 installed. Could be the installation process differ from the enterprise edition? Run as administrator doesn't work ...
Tm1 Install Error.png (4.93 KiB) Viewed 4270 times
clubjoker wrote:we have ibm cognos express 9.5 installed.
Don't you think that would have been relevant information to include in your original post? I'm pretty sure the ability to link TM1 with other systems (via the OLEDB for OLAP driver) is not part of the Cognos Express licensing. That might explain why it isn't included, perhaps others will know for sure (I've never implemented CE).
