Export to PDF Error
amitbehere2002
Version: 9.5.2
Excel Version: Excel 2007
Export to PDF Error
Post by amitbehere2002 »
I have Installed TM1 10.1.1 on my Machine for Windows 7 64 Bit
Whenever i am trying to export to PDF from TM1 Web i am getting following Error
Error while Printing from TM1Web for Windows 7
PDF Camp Print Error.jpg (41.9 KiB) Viewed 5897 times
Amit
qml
Excel Version: 2007 - 2016
Re: Export to PDF Error
Post by qml »
Make sure that the PDFcamp Printer is:
a) installed,
b) set as default.
Also make sure all TM1 services are being run by the same service account.
Finally, restart the TM1ExcelService.
Kamil Arendt
amitbehere2002
Version: 9.5.2
Thanks a lot for your Help
Now i am able to Export the cube view to PDF but i am getting another error after exporting to PDF while opening the PDF File
Following is the Snapshot for the same
PDF Camp After Print error
PDF Camp after Print Error.jpg (29.24 KiB) Viewed 5871 times
Following are the System Configuration
1. TM1 10.1.1
2. Adobe Reader 10
Do let me know for the same
Amit
amitbehere2002
Version: 9.5.2
Thanks a lot All the Errors Solved
But i need a help can we Export to Page in "Fit to Selection Mode"
Please do let me know for the same
Amit
amitbehere2002 wrote:Thanks a lot All the Errors Solved
Amit
Did you pay no attention the last time?
http://www.tm1forum.com/viewtopic.php?f=3&t=8631
amitbehere2002
Version: 9.5.2
Hi Lotsaram,
In TM1 9.5.2 if we need to Export to PDF from Tm1Web we need to Set the Page Orientation in PDF Cam Driver in Control Panel of Windows
Where only 3 Options are available which are as follows
1. Portrait
2. Landscape
2. Landscape Reversed
After Working on all possible things i have asked the Question for "Fit to Selection Mode"
That doesnt mean i have not paid the Attention on the Last Post
Anyways thanks a lot for suggestion
i just want to know if any one had tried on the option of Fit to Selection mode
Amit
khk19
Version: 9.4-9.5.1-9.5.2
Excel Version: 2003-2007-2010
Post by khk19 »
Hi Amit,
I've got the same error message "adobe reader could not open <FileName>.pdf", can you please post the solutions how you resolved the issue that will be really helpful.
KHK.
