incorrect }StatsByCube values?
ioscat
OLAP Product: Contributor
Version: 9.5.2 10.1.1 10.2
Excel Version: 07+10+13
Post by ioscat »
Hello, community!
Got a strange behaviour while developing model. Number of fed cells in }StatsByCube is zero while values are normally aggregated at consolidated levels.
How is it possible?
Martin Ryan
Re: incorrect }StatsByCube values?
Post by Martin Ryan »
This might be a little too obvious, but perhaps you have skipcheck turned off?
Jodi Ryan Family Lawyer
ioscat
Post by ioscat »
no, therea are about 10^(8 or 10) cells, so if skipcheck was switched off i won't be able to get any result at top level. When i fill manually source cube (where feeders are fired from) stats by cube show numbers correctly, but after restart i get this one from first post.
Darkhorse
Excel Version: 2003 2007 2010 2013
Post by Darkhorse »
this is a similar issue to sttsbyclientbycube its a fix that hasnt arrived yet
ioscat
Post by ioscat »
could you explain, what do you mean?
ioscat wrote:could you explain, what do you mean?
I believe that this is what was being referred to.
Also discussed here.
I haven't checked whether it's still borked in 10.1 yet but it wouldn't surprise me; it doesn't involve semi-transparent multi-coloured fly-outs that look kewl in potential customer demos, so who needs to bother fixing or updating core functionality?
I believe that Darkhorse's point was that if some }Stats operations are broken, it's not impossible that others are.
ioscat
Post by ioscat »
Thanks for extended answer.
