Folks
In Performance Modeler:
Have deleted applications using standard front end. Then tried to create new application using the same underlying 'model' with same approval hierarchy as before:
Error:
The Approval Hierarchy dimension 'xxxxxx' is being used by appliction '{5c8ba7c1-1cd7-4567-8182-07827b195afb}
After some grumbling i created a new Approval hierarchy and applied to all cubes in the model
Error
The cubeview 'xxxxxx' is being used by appliction '{5c8ba7c1-1cd7-4567-8182-07827b195afb}
Clearly the cleanup of internal metadata is still thinking the old/deleted application still exists.
Found bunch of control cubes relating to application state. Very loath to simply delete then. IS there a control cube clean up job i can run. Have already restarted the TM1 Server but no help.
See attachment for control cubes in question:
}TP_Application_State
Cleanup of Metadata after deleting Contributor App. V10
Mark H
- Version: 10.1
- tp_applications_metadata.JPG (50.52 KiB) Viewed 4151 times
- sachin
- OLAP Product: Transformer,SSAS, EP, TM1
- Version: 7.3 2005 10.1 10.1.1
- Excel Version: 2013
Re: Cleanup of Metadata after deleting Contributor App. V10
Have you restarted your service AFTER you delete the application? Sometime that can clear orphan/unused metadataMark H wrote:Folks
Mark H
- Version: 10.1
Yes, tried that. Problem persists
Mark H
- Version: 10.1
Found the solution:
There is a TI process we can use to 'clean-up'. Perhaps one day will invent menu driven options
http://www-01.ibm.com/support/docview.w ... wg21542848
It works.
M
It works.
M
