I want a rule for a cell A which depends on cell B, however cell B depends on cell C (Cell C has been entered manually and is not rule driven).
Is this possible?
How can I achieve this?
An example below:
In the first cube, the highlighted cells are calculated based on the top left cell (are set to be the same value of '1').
I now want other 'businessunit' dimension elements eg. BT to be calculated based on these highlighted cells.
I've tried it but it doesn't seem to work, it seems as if the cube doesnt know about its own calculated cells until after everything is done.
I was hoping there would be some kind of 'touch' function that would evaluate everything so that further rules could make use of already calculated cells.
Rules for cells based on rule based cells
- cubes.JPG (150.87 KiB) Viewed 6870 times
Re: Rules for cells based on rule based cells
The data being entered are strings...
[quote="nhavis"]I want a rule for a cell A which depends on cell B, however cell B depends on cell C (Cell C has been entered manually and is not rule driven).
Is this possible?
Yes, it's certainly possible. Multi-level rules are common. All you need to do is:
- Define the area that includes cell B based on cell C;
- Define the area that includes cell A based on cell B.
Usually if you don't get the right result it's either a problem with your rule syntax, or your feeders.
It may be an idea to post the actual rules that you're using, including the feeders.
Is this possible?
ScottW
- OLAP Product: TM1 CX
- Version: 9.5 9.4.1 9.1.4 9.0 8.4
- Excel Version: 2003 2007
Unless you exceed the stack in a recursive calculation there is nothing to prohibit a rule calculated cell being dependent upon another rule calculated cell. You would need quite a long chain of calculations before hitting this limit. Typically this in only ever encountered with closing stock / opening stock type calculations.
More than likely the issue is with your rule syntax. It might be helpful if you post an example of your rules and feeders.
If you are using string input:
1/ Why?
2/ are you using full DB notation to retrieve string values and FeedStrings statement?
If you are as I suspect trying to rebuild an EP model in TM1 then I would advise against trying to recreate the equivalent structures in TM1. The design principles are fundamentally quite different and to achieve the same functional spec the best TM1 design is likely to not resemble an Analyst model at all.
1/ Why?
ScottW
I see I have posted an echo ...
Oh thanks - it turns out I was referencing the entry cube and that's why no values were appearing.
I'm not sure what an EP model is... could you explain further?ScottW wrote:If you are as I suspect trying to rebuild an EP model in TM1 then I would advise against trying to recreate the equivalent structures in TM1. The design principles are fundamentally quite different and to achieve the same functional spec the best TM1 design is likely to not resemble an Analyst model at all.
- John Hobson
- OLAP Product: Any
- Version: 1.0
- Excel Version: 2020
and also for those of us who need to use that so rarely required concept of maximum or minimumTypically this in only ever encountered with closing stock / opening stock type calculations.
John Hobson
The Planning Factory
ScottW
EP = Cognos Enterprise Planning
Clearly my 6th sense was a bit off. I just thought your cube design smacked of being transposed from another system ...
