Quesiton about TM1 Cognos Insight
sun
OLAP Product: TM1 Cognos
Version: 9.5
Post by sun »
i'm am starting to use this tool, and have one problem.
When i enter positive value, for example 1-->it returns 1, that's ok. Problem is when i enter negative values,
for example if i enter -1-->in cell returns result as -10, or -100. Why is result numberd x10, or x100? But only negative values.
I can't find setting for this??
thank you
qml
Excel Version: 2007 - 2016
Re: Quesiton about TM1 Cognos Insight
Post by qml »
Which version are you using and which mode (connected/distributed/standalone)? I cannot reproduce your problem in 10.2.
Also, which one is it, does it multiply numbers by 10 or 100? Or does it choose the multiplier randomly?
Kamil Arendt
sun
Version: 9.5
Post by sun »
Thank you for your help, and sorry for lack of information.
I'm using 10.1.1. connected.
And factor is 10x
So if i put -1 result is -10
Many thanks.
sun
Version: 9.5
Post by sun »
Anybody else?
qml
Post by qml »
Does it happen for every measure in every view? Every cube? Every model?
Kamil Arendt
sun
Version: 9.5
Post by sun »
Yes.. But i'am new in this tool so, is somewhere my mistake i understand :).
I noticed that, every time i try to insert number, it put's me out what kind of spread i whant, sometimes i can do relative proportional spread, and then is result ok, but most of time is available just equal spread then is result x10.
If i put in postive number it doesn't mind what kind of spread i choose, result is ok.
qml
Post by qml »
It looks like user error then. You are trying to input numbers at consolidated level (typically you would do it on the lowest level, also called N level or leaf level). In such case Cognos Insight offers you a choice of data spreading methods and depending on the type of spread you choose and its parameters, you might end up putting your 1 or -1 on every leaf element under the chosen consolidation, which then sums up to, say, -10 on that consolidated level.
Kamil Arendt
sun
Version: 9.5
Post by sun »
Hm... i try on diferent cubes, aplication. I don't understand.. Maybee i put sometimes to consolidated level, but in times when i don't get spread, also give x10 for negative values. And why he doesn't sume positive values if i put to conslidated levels and spread them?
Sorry for bothering you.
qml
Post by qml »
Well it's really hard to give you anything more concrete as you're not providing enough detail here.
Do you think you could describe in detail the steps you are taking with the result you are getting? Preferably with screenshots...
Kamil Arendt
sun
Version: 9.5
Post by sun »
today we take some tests and find out. Problem is that when we put before number + or -, is result multiple x 10.
If i wrote 1*-1=1 So if i wrote formule is ok, if i write -1=-10 or +1=10
Mark H
Post by Mark H »
I cannot replicate this problem.
If you enter data at the lowest level then +1 or -1 is doing what we expect.
Entering +1 , +10 etc at aggregate leve(spread) also spreads data with the increase.
Perhaps you can attach a screen print to show the problem in more detail ?
Mark H
sun
Version: 9.5
Post by sun »
when i put number
slika pri vnosu.jpg (35.4 KiB) Viewed 8788 times
result
slika po vnosu.jpg (35.15 KiB) Viewed 8788 times
1*-1
In general when is in firts place - or + result is -10, or +10
sun
Version: 9.5
Post by sun »
This problem is by different customers, differnt cubes, we try in connected or distributed, so whole different thing..
sun
Version: 9.5
Post by sun »
