I am getting an error 1608, through our forum i got information to resolve that, I tried that. Still the admin server is not running.
But here I am missing a step, please can anyone rectify it. Please find the screen shots for it,
Thank you
TM1 9.5.2
excel 2007
Admin server is not starting
charan
- OLAP Product: cognos tm1
- Version: 9.5
- Services.JPG (149.49 KiB) Viewed 5247 times
- cmd.JPG (89.75 KiB) Viewed 5247 times
Jodha
- Version: 9.5.2 10.1 10.2
- Excel Version: 2007 2010 SP1
Re: Admin server is not starting
Try this
1)Empty log folder and restart the server
2)check for user name and password if your login as domain user
I'm coming late to the party on this, but I missed the original posts and didn't notice this thread until Jodha's post above.
I'm not sure why the Admin Server service would be saying that "the dependency service or group" failed to start because it doesn't depend on any other system components, as the Dependencies tab should show. (The servers on that box do depend on it, but that shouldn't prevent the Admin Server from starting. I'm assuming from your screenshot that you were trying to load that one rather than one of the servers.)
However... I do note in your screenshot (thanks for adding one of those, a picture may well be worth the proverbial thousand words here) that you installed the server service using the user name \Karnaker. And judging from the seeming lack of a period in front of the Log On As entry for the Admin Server, it looks like you may have done the same thing there.
If I recall correctly the standard installation package warns that you may encounter problems if you don't enter the user name in the format:
DomainName\UserName
or
MachineName\UserName
as the case may be.
This may well be an example of that.
Try uninstalling and when you reinstall, make sure that you add either the domain or machine name ahead of your user ID and see whether that works.
DomainName\UserName
or
as the case may be.
tushar.marathe
- Version: 9.5.2
We had a similar issue once because the domain password had "expired". Please check if there is any expiry setup on the admin user password.
