Script Error CX_GEN_TITLE When logging in using Gateway
jameswebber
Version: CE 10.1.1
Post by jameswebber »
I'm getting this issue on CE 10.1
I'm using cognos gateway to pass straight through into Cognos Express
Documented here: http://www.ibm.com/developerworks/data/ ... ml?ca=drs-
This work fine accessing the IE link
i.e:
http://<servername>/IBMCognosExpress/cgi-bin/cognos.cgi?b_action=xts.run&m=portal/main.xts&startwel=yes
But not via xcelerator or advisor
Going to: http://<servername>/IBMCognosExpress/cgi-bin/cognos.cgi?b_action=xts.run&m=portal/close.xts&h_CAM_action=logon&ui.compid=rs
I get the error
Script Error
Script Error
Microsoft Excel - Book1 - Remote_2012-08-24_17-09-36.gif (37.39 KiB) Viewed 4432 times
It works if I click yes.
I checked that cognos configuration and my CAMURI settings in tm1cfg were the same server name
as per this http://grwebdev:8090/browse/CE-79?focus ... ment-12408
So I have ended up:
Disable Internet Explorer script error debugging, by performing the following on the client device:
1. Launch 'Internet Explorer'
2. In the top menu, click 'Tools' and then 'Internet Options'
3. Click on the 'Advanced' tab
4. Locate the section 'Browsing'
5. Locate the option “Disable Script Debugging” and tick the box beside it
6. Locate the option “Display a notification about every script error” and untick the box beside it.
As per http://www-01.ibm.com/support/docview.w ... wg21432490
I feel dirty inside :oops:
Anyone else think/know of a better soultion?
jameswebber
Version: CE 10.1.1
Re: Script Error CX_GEN_TITLE When logging in using Gateway
I'm finding this fix only works for local PC's and not PC's I am RDped into or citrix.
Such as shame I may need to turn off SSO because of this
jameswebber
Version: CE 10.1.1
Finally fixed this buy following some of the steps listed here:
http://queryvision.com/wp-content/uploa ... ectory.pdf
