anyone having any issue of slow respond time from the server for users who located far away ? I have a user located 3000km away from the server and after typing in username and password, it takes up to 6 minutes before she manage to login.
I have asked the network team to check the network, doesn't seems like there is any issue.
currently we are using cognos express 9.5.
Slow Response time
- Martin Ryan
- Version: 10.1
Re: Slow Response time
TM1 is generally not very good over the network. Six minutes sounds worse than usual, but generally running TM1 over a WAN is not a good idea. You either need to look at a Terminal Services/Citrix environment or use Tm1 Contributor.
Another (unlikely) scenario that might possibly be the reason if you're problem has been slightly misstated, is that a local server is starting up. Check this is disabled.
Martin
Martin
Jodi Ryan Family Lawyer
