Installing Tm1top on Cognos Express 10.1 client
jameswebber
Version: CE 10.1.1
Post by jameswebber »
Has anyone setup Tm1top on their laptop/pc?
I have it working fine on the server but it’s not installed as part of the Xcelerator Client install.
My PC is a 64 bit win 7 PC so should work if I can get the right files/ install.
Simply copying the tm1top.exe and tm1top.ini is not enough.
Couldn’t find any reference to this in the IBM documentation
http://publib.boulder.ibm.com/infocente ... 1top%22%20
Seems like this in in limbo since there is no operations console in CE http://www-304.ibm.com/support/docview. ... wg21584658
Re: Installing Tm1top on Cognos Express 10.1 client
Hi James - do a search for tm1top + DLL. All you should need is the required DLLs and the SSL directory plus tm1top.exe and tm1top.ini. You can place this wherever just as long as the tm1top.exe is in the same root directory as the DLLs. Thsi is how it has always been and I doubt very much that it would be any different for CX.
kpk
OLAP Product: TM1, CX
Version: TM1 7x 8x 9x 10x CX 9.5 10.1
Excel Version: XP 2003 2007 2010
Post by kpk »
jameswebber wrote:Has anyone setup Tm1top on their laptop/pc?
FYI:
From license perspectives you are not allowed to use TM1Top with Xcelerator Client license (you need an Administrator license).
That is my latest information.
Best Regards,
Peter
jameswebber
Version: CE 10.1.1
Livening might effect my super users but since I am the admin I will get over putting it on the server and my machine.
Doing it might be the challenge though as the old version did not display CAM/AD users correctly.
I see they have fixed this but following the IBM 9.5 instructions for this:
https://www-304.ibm.com/support/docview ... wg21470097
Results in the particularly helpful error message.
TM1 Forum • Post a reply - Google Chrome_2012-06-19_08-30-43.png (75.2 KiB) Viewed 5622 times
But thanks for the advice lotsaram and Peter
jameswebber
Version: CE 10.1.1
In the end i copied the whole 64bit dir to my PC.
This worked but only if your PC is a windows 7 computer it's a 64 bit exe so wont work on a 32 bit XP machine
