Removing Redundant Children from alternative hirearchies
jameswebber
Version: CE 10.1.1
Post by jameswebber »
Removing Redundant Children from alternative hierarchies
Hi just after some tips for the best way to clean up a dimension with multiple hierarchies.
I’m using TI to create a number of additional hierarchies based on attributes:
IF (PContract@='');
   PContract= 'Unspec Contract';
ENDIF;
IF (DIMIX(DimName,PContract)=0);
   DimensionElementInsert(DimName, '', PContract,  'C');
   DimensionElementComponentAdd(DimName, 'Total Project ID by Contract', PContract, 1);
ENDIF;
DimensionElementComponentAdd(DimName, PContract, ElName, 1);
These attributes are getting populated via ODBC but I hadn’t anticipated that the attribute can change. Creating double ups in my alternative hierarchy E.g Project 1 in both places below:
AttributeA
  • Project 1
    Project 3
AttributeB
  • Project 1
    Project 2
I looked at Ben Hills example and modified it http://blog.tm1tutorials.com/tag/dimens ... entdelete/
This is because I want to unwind my hierarchy but not the other hierarchies in the system
I created TI that looks up the parent sees if it’s one I’m interested in then finds the children and removes them from the dimension see below:
vIndex = 1;
vElParN = ELPARN(DimName, Project_ID);
While (vIndex<=vElParN);
   vElPar  = ELPAR (DimName, Project_id, vindex);
## This code is to unwind the project hierarchies but only for the project hierarchies we are creating in Dim Project ID 7. Consolidation by Class
## This is because the TI there adds into the hierarchy but does not delete redundant ones
## Added by James Webber IRL 120427 see TMI-241
## Based on Ben Hills Example http://blog.tm1tutorials.com/tag/dimensionelementcomponentdelete/
# Frist lets check to see if the Parent of the project is total contract
If (vElpar @= 'Total Project ID by Contract');
   # Now how many children are there underneath?
      ChildCount =  ELCOMPN(DimName, Project_Id);
                  # find the name of each of the children
                 WHILE(ChildCount > 0);
                 sChildElm = ELCOMP(DimName, Project_Id,ChildCount);
                      #Now check the child name is an ancestor (child) of the project_ID, i.e the node in this case
                       #IF (ELISANC(DimName, Project_Id, sChildElm) = 1);
                       # If so remove it from the hierarchy
                       DimensionElementComponentDelete(DimName, Project_Id, sChildElm);
                       #ENDIF;
                ChildCount = ChildCount - 1;
               end;
ENDIF;
vElParN = vElParN-1;
END;
This works but does anyone know of a more elegant way to find out all elements under an alternative hierarchy and remove these entries from the dimension?
I.e. is there a more elegant way of doing this?
jameswebber
Version: CE 10.1.1
Re: Removing Redundant Children from alternative hirearchies
Just wondering if my double entry is really caused but the users not reloading the view rather than simply choosing the refresh button
tm1-test -_2012-04-26_Refressh.png (29.87 KiB) Viewed 4155 times
I have noticed in testing that I get double entries in the hierarchy if I don't choose reload. Even commented out my TI process and it seems to be okay.
Bedrock.Dim.Unwind.TargetConsol
jameswebber
Version: CE 10.1.1
Thanks Lotsaram,
Bedrock.Dim.Hierarchy.Unwind.Consolidation seems to work fine just needed to make sure pRecursive is set to 1 (Delete all the relationsips from all the elements under the nominated consolidation)
Otherwise there is a lot of orphans floating around.
