TM1 on Microsoft Hyper-V
chewza
- Version: 9.5
- Excel Version: 7
Hi there
Anyone know if TM1 is supported on MS Hyper-V as a virtual environment? My question relates to Tm1 Server as well as perspectives, but am most interested in whether perspectives is supported.
Many thanks!
Chris
Many thanks!
Chris
Re: TM1 on Microsoft Hyper-V
Officially IBM doesn't "support" any virtualization platforms per se, it is the OS that the TM1 server or client is running on that is supported or not.chewza wrote:Hi there
Many thanks!
Chris
- jim wood
- Version: PA 2.0.7
I've not installed it on Hyper-V but I have (as lotsaram said) been able to get it working on server 2008 on Oracle Virtual Box. I've also used microsofts old virtual machine without a problem.
nick_leeson
- OLAP Product: TM1 9x, BPC, Hyperion, HANA
- Version: TM1 10
- Excel Version: Excel 2003 - 2010
Have a client working on Microsoft Application Virtualization (also known as App-V) and TM1 works like a charm.
jsolanki
- Version: 9.5.1
- Excel Version: 14
I am trying to sequence IBM Cognos TM1 9.5.1 using App-V 5.0. I have merged all possible folders under VFS (Package Files), I have also ticked Allow all named objects to interact with the local system and Allow all COM objects to interact with the local system on advanced tab of App-V .
But I still get below error message when I launch my TM1
Run-time error '429': ActiveX component can't create object.
I have got preinstalled MS Office 2010 Professional Plus i.e. Word, Excel and PowerPoint. (I have also tried add Access 2010)
How do I resolve this issue???
Any help will be highly appreciated.
Jignesh
Jignesh
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
Office 2010 is not supported under TM1 9.5.1; you need 9.5.2 at least. Probably won't solve your issue but will likley cause a problem if you try and get support from IBM.jsolanki wrote:I am trying to sequence IBM Cognos TM1 9.5.1......
Jignesh
jsolanki
- Version: 9.5.1
- Excel Version: 14
But I have tried the native install and it works fine with office 2010 and Office 2007 both. Only App-V package is giving issue. Not only I tried the AppV package with office 2007 and I get the same error there too.
Jignesh
Jignesh
nick_leeson
- Version: TM1 10
mate,
if you post the error I could have a look and get back to you.
jsolanki
- Version: 9.5.1
- Excel Version: 14
My apology for few wrong information above.
I would like to correct myself.
I have retested the native install and App-V install both with Office 2007 and Office 2010 both every time I launch the Perspective for MS Excel from start menu, I get attached error message. i.e.
Command line I am using to install the application is as below
"%~dp0setup.exe" /l1033 /v"INSTALLLEVEL=0 ADDLOCAL=TM1Client,TM1_OLEDB_Provider,Perspectives,PDFCamp PRODUCTCHOSEN=TM1P EXCELEDITINCELL=True TM1AUTOLOAD=False EXCELTOOLSVRHOST=tm1 TM1LANGSTRING=ENG CLIENTLOGIN=F TM1CLIENTADMHOST=tm1 /qn"
Your help will be highly appreciated.
Thanks with regards
Thanks with regards
- Image.PNG (9.06 KiB) Viewed 10258 times
jsolanki
- Version: 9.5.1
- Excel Version: 14
Just to let you know target operating system is Windows 7 x86 Enterprise
- Michel Zijlema
- OLAP Product: TM1, PALO
The Install Guide specifies some software prerequistites to be installed - one of them being the Microsoft Visual C++ 2005 SP1 Redistributable Package. Could it be that this component is missing?jsolanki wrote:I have retested the native install and App-V install both with Office 2007 and Office 2010 both every time I launch the Perspective for MS Excel from start menu, I get attached error message. i.e.
Michel
jsolanki
- Version: 9.5.1
- Excel Version: 14
I found the article which shows that this is known issue as below
http://www-01.ibm.com/support/docview.w ... 1371&aid=1
re register the dll n ocx and got it going. But still could get the AppV application going. Finally packaged the software as native.
