To Restrict an user to enter date value for a date field
manoj928
OLAP Product: IBM Cognos TM1
Version: 10.2.1
Post by manoj928 »
Hello All,
How i can restrict an user to enter date only value in a date field with format MM/DD/YYYY. I tried it using Custom Style, i set the format as MM/DD/YYYY, but i can see, field is still accepting a string value instead.
Your help will be really appreciated.
Manoj
Re: To Restrict an user to enter date value for a date field
manoj928 wrote: How i can restrict an user to enter date only value in a date field with format MM/DD/YYYY. I tried it using Custom Style, i set the format as MM/DD/YYYY, but i can see, field is still accepting a string value instead.
And where exactly is this "date field"? In a cube, in a worksheet, in something else? Because TM1 does not have date fields, as explained here.
manoj928
Version: 10.2.1
Post by manoj928 »
Thanks for reply,
Actually users will enter data in cube through web-sheets and in any data field, we want them to enter value in format MM/DD/YYYY. So what is best way to achieve it?
