Chaps,
When you set CAM single sign on does TM1 Web behave in teh same way as Architect or teh Excel Addin? The reason I ask is that when you have BI linked to windows containers and you have CAM security set in TM1 you are not prmpted for a password when opening Architect. I am however not sure if Web will behave in teh same as it hjas it's own API,
TM1 Web and CAM Single Sign On.
- jim wood
- Version: PA 2.0.7
- jameswebber
- OLAP Product: Cognos Express 10
- Version: CE 10.1.1
Re: TM1 Web and CAM Single Sign On.
Hey Jim,
Is this in Tm1 enterprise?
I have setup CAM SSO in Cognos express using
http://www.ibm.com/developerworks/data/ ... ml?ca=drs-
So I can check TM1 web in there if you want.. not sure if it will be the same.
- jim wood
- Version: PA 2.0.7
Hi James,
It is enterprise and not express. I'm not sure if they will behave differently. If you could have a look that would be great though,
rmackenzie
Yes, it functions pretty much the same. You goto the login page and click the login button and there is no request for a username or password. Is that what you mean?jim wood wrote:When you set CAM single sign on does TM1 Web behave in teh same way as Architect or teh Excel Addin?
Robin Mackenzie
- jim wood
- Version: PA 2.0.7
That's what I was after thank you.
