please find the attachment, i have an issue with the branch and franchise, the branch codes are repeating for franchise and franchise codes for branch as well.
I have changed by giving prefixes.
Thanks and regards
TM1 9.5
excel 2007
Sorting of elements
viswaraju
- OLAP Product: IBM COGNOS TM1
- Version: 9.5
Sorting of elements
- hierarchy issue
- HIERARCHY.jpg (46.02 KiB) Viewed 2516 times
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Re: Sorting of elements
If you could reply attaching the process (file with .PRO extension) that builds this dimension and the datasource from which it get the members it will be easier to see what the problem is. I am presuming by the way that this is a continuation of the "Filters in TM1" thread.
Duncan.
Duncan.
- vinnusea
- Version: 10.2
Yes
The repeating or circular loops may occur if the Data Source you are loading have repeating hierarchy.Until and unless you provide your data source or a sample source which is exactly similar to your source and your process file (.Pro) then i or any one can help you out.
Vinnusea
Vinnusea
