PDF of Contributor developer documentation
MillerJD
Version: 9.5.2
Post by MillerJD »
Anyone have a link to the PDF version of developer documentation for TM1 contributor?
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: PDF of Contributor developer documentation
Post by Michel Zijlema »
MillerJD wrote:Anyone have a link to the PDF version of developer documentation for TM1 contributor?
Here you go.
Michel
I'm not sure whether there is one under that title; I'm not even seeing that on the web site version of the help. There's only the TM1 Developer Guide.
Links to the .pdfs will be found in the FAQ thread (specifically, a link to this page), though I have to add in one to the Cognos Express .pdf page as well (which is here).
MillerJD
Version: 9.5.2
Post by MillerJD »
that link is just a users guide, i'm looking for more of the "admin and deploy" contributor application development...
jim wood
Version: PA 2.0.7
Post by jim wood »
I've only seen contributor covered in the installation guide. I'm not sure if it is anywhere else in the standard documentation. There are also no videos that cover TM1 contributor on You Tube. Alan, I see a gap in video guide market.......
Michel Zijlema
MillerJD wrote:that link is just a users guide, i'm looking for more of the "admin and deploy" contributor application development...
What about the "TM1 Contributor Administrator" pdf that is in the list of documents?
Michel
jim wood
Version: PA 2.0.7
Post by jim wood »
Michel Zijlema wrote:What about the "TM1 Contributor Administrator"
..... in almost every language as well.
A good find as well btw. I've started to play with contributor and I was surprised by the lack of documentation with the install.
MillerJD
Version: 9.5.2
Post by MillerJD »
yep - i got it - thanks!
moby91
Version: 9.5.1
Excel Version: 2003 2007
Post by moby91 »
http://www.ibm.com/developerworks/data/ ... ge460.html
Configure TM1 9.5 Contributor with Apache Tomcat
Summary: Deploying the TM1 Contributor application in Apache Tomcat.
http://public.dhe.ibm.com/software/dw/d ... apache.pdf
http://www.ibm.com/developerworks/data/ ... ge459.html
Configure TM1 9.5 Contributor with Websphere CE
Summary: Deploying the TM1 Contributor application in IBM Websphere CE.
http://public.dhe.ibm.com/software/dw/d ... ere_ce.pdf
https://www-304.ibm.com/support/docview ... wg21439994
Upgrading TM1 Contributor
Flash (Alert)
Abstract
To upgrade your Contributor applications from 9.5.0 to 9.5.1 you must perform specific steps.
