Hello guys,
Im experiencing a problem on summing up the child values generated by the rule i made. See my attached screenshot.
This is my current rule:
SKIPCHECK;
['Number Buying Accounts']=IF(ELLEV('tsUBA Accounts',!tsUBA Accounts)=0, IF(['Product Lines Bought']=0,STET,1),1);
What do i need to do in order be able to sum up the child values?
Your help is greatly appreciated.
How do i sum up the values generated from rule?
crash0verride
- Version: TM1 9.0.1.181 SP3
- Excel Version: MS Excel 2003 SP3
- Clipboard01.png (21.5 KiB) Viewed 7046 times
Martin Erlmoser
- Version: 9.1.4 FP1
Re: How do i sum up the values generated from rule?
I'm not a rule expert (so maybe i'm talking ****) but
- you can define that the rule only points on N: Elements
- or you exclude the Consolidation with stet from the rule
depends on what you need
regards,
martin
regards,
martin
- Steve Rowe
You have two problems
1 Write your rule so it applies to the N level only
['Number Buying Accounts']= N:
2 You will need to feed the rule (or remove the skipcheck not recommended).
Feeders;
['Product Lines Bought']=>['Number Buying Accounts'];
If I'm understanding what your trying to do (count the number of prodict sales). I think the last ",1);" needs to be 0); or you will be conting all 0 level accounts irrespective of Product Lines Boght. If your rule is correct as written with the last 1 in place, then I think your rule is "impossible" to feed since the last 1 is not dependant on any other value in the system.
HTH don't have tme for more detail...
Feeders;
- paulsimon
- Version: PA 2.0.5
I think you need something like the following:
SKIPCHECK;
['Number Buying Accounts']=N:
IF( ELLEV('tsUBA Accounts',!tsUBA Accounts)=0 & ['Product Lines Bought']>0
1
0
Feeders ;
['Product Lines Bought'] => ['Number Buying Accounts'] ;
Consolidation in the tsUBA Accounts dimension which I presume has one entry per buying account at the base level, will do the rest. You just need to make the rule generate a 1 for each buying account, at the base level.
SKIPCHECK;
1
0
Feeders ;
gnampoothiry
Hi Guys,
What if in a cube I am having price which at a child item level is an input and an average at consolidation.
For Eg:-
Jan Feb Mar Q1
10 20 30 20
Is there any function in TM1 which can handle this?
Girish
For Eg:-
Jan Feb Mar Q1
10 20 30 20
Girish
- John Hobson
- OLAP Product: Any
- Version: 1.0
- Excel Version: 2020
This is very common Girish
Set up a rule restricted to the C: level only saying something like
[ 'Price'] = C: [ 'Sales Value'] \ ([ 'Sales Units'];
If you want to be very careful you might also have
[ 'Price'] = N: Stet;
which will ensure that the Price is enterable at base level
John Hobson
The Planning Factory
- Martin Ryan
- Version: 10.1
I've put in a post here to suggest best practices for Averaging as it is indeed a common issue with TM1.
Martin
Martin
Jodi Ryan Family Lawyer
