Extended TM1top
Steve Vincent
Version: 10.2.2 FP1
Extended TM1top
Post by Steve Vincent »
Here is Ben Hills extended version of TM1top;
TM1top.zip
(2.4 MiB) Downloaded 3932 times
Re: Extended TM1top
Note I could not get this to work on version 845 of TM1, not sure if it doesn't support the first release of TM1Top or if I am doing something wrong.
Kyro
OLAP Product: MODLR - The CPM Cloud
Version: Always the latest.
Excel Version: 365
Re: Extended TM1top
Post by Kyro »
I'm unsure but I think that the attached is the version adapted for TM1 9.X's new locking status top fields. I'll take a look and see if I have older versions. I might as well support it.
Ben
*Edit: Here is a newer 9.1X version - Tested with 9.1 SP4
http://www.tm1tutorials.com/downloads/TM1top%209.1X.zip
I'll create other versions when I next upgrade to 9.4 and next downgrade to 9.0
Steve Vincent
Version: 10.2.2 FP1
Re: Extended TM1top
the 9.0 version kind of works on 9.5 but various bits don't (like status colour changes when server is busy). Are there any plans to release a 9.5 compatible version because this is streets ahead of what IBM offer...
Kyro
Excel Version: 365
Re: Extended TM1top
Post by Kyro »
Sure, I'll take a look when I next get some time off Keystone.
anoops81
Version: 9.5.2
Excel Version: Office 2010
Re: Extended TM1top
Post by anoops81 »
Hi Steve/Kyro ,
I have configured the Extended TM1top in our server . I am able to monitor the clients also. Could you please tell me where i can find the explanation on the colors which is coming live in the Extended tm1top application ? Please provide me the link , so that I can go through.
Anoop
mce
Excel Version: 2013 2016
Re: Extended TM1top
Post by mce »
Steve Vincent wrote:Here is Ben Hills extended version of TM1top;
TM1top.zip
I downloaded this into my client machine and configured for the TM1 server. It opens fine. But it does fail when I verify access even when entering correct credentials. It gives "Couldnot Verify:Authentication Failed" error message.
- Do I have to copy any of these files into server's Applix\bin directory?
- Does version 1.0 of TM1Top works well in 9.0 SP1?
Thanks in advance.
mce
Re: Extended TM1top
Post by mce »
TM1 Top Custom Client.pdf wrote: Copy the files listed below from your old TM1 top Directory into the new TM1
Top Directory Replacing the Existing Files:
a. Tm1api.dll
b. Tm1lib.dll
c. Tm1sip.dll
In version 9.0, there is no TM1Top, so there is no TM1Top directory. Should I replace these files in Applix\bin folder with the ones coming in TM1top.zip ?
Re: Extended TM1top
a. Tm1api.dll
b. Tm1lib.dll
c. Tm1sip.dll
Other way around. Copy those files out of your Applix\bin directory and put them into your TM1Top one to make sure that they're the current ones for your version. You don't need a system-created TM1Top directory; you can extract the files into any folder that you create. In my case I just created a folder that sits alongside the data directories, unpacked the files into there and copied the three files in from Applix/bin.
mce
Re: Extended TM1top
Post by mce »
When I copy these 3 files from applix\bin to the tm1top folder, tm1top works but veryfiy still does not work and I receive the error message below.
mce
Re: Extended TM1top
Post by mce »
I am still having problems with TM1Top in version 9.0. I am able to monitor and but not able to verify and kill procceses or disconnect users.
Is there any other way in TM1 to kill hanging user requests or to disconnect hanging users?
Any help will be highly appreciated.
mce
Re: Extended TM1top
Post by mce »
Here is the response frm IBoglix;
Unfortunately, TM1TOP is not compatible with 9.0.1. The first fully compatible release is 9.0.2.
applix_mc
Re: Extended TM1top
Post by applix_mc »
Just an observation but if anyone is trying to use this Tm1Top version beyond 9.1.x you will run into problems because there is no tm1sip.dll created for Tm1 versions 9.4 >.
Re: Extended TM1top
applix_mc wrote:Just an observation but if anyone is trying to use this Tm1Top version beyond 9.1.x you will run into problems because there is no tm1sip.dll created for Tm1 versions 9.4 >.
It works well enough with 9.5.1 with v 8.0000 of tm1api, tm1lib and tm1sip for display only purposes but some of the fields are a little screwed up (eg lock is duplicated, wait time does not display) and although you can verrify it isn't possible to kill a thread.
If @kaikyro is listening, Ben I'd be interested if you might considder supporting 9.4 and 9.5 ...
Kyro
Excel Version: 365
Re: Extended TM1top
Post by Kyro »
I have a version in progress currently. Will send an update shortly.
harrytm1
Version: Latest version
Excel Version: 2003 to 2019
Re: Extended TM1top
Post by harrytm1 »
Using it with version 9.5.2. Seems ok but the wait time is not showing. I managed to kill a hung TI using it. Unless it is really coincidental that the TI ended by itself right after I killed it through Extended TM1Top, it is working.
winsonlee
OLAP Product: Cognos Express
Version: 9.5
Re: Extended TM1top
Post by winsonlee »
hi kyro.
i tried downloading TM1top%209.1X.zip but the link is broken.
Does the TM1top%209.1X.zip work on Cognos Express 9.5 ?
show75
OLAP Product: oracle and sql server
Version: TM1 9
Re: Extended TM1top
Post by show75 »
I can not end any process execute or object duplicate .
there is one way... restart service.
is there any solution to this issue?
I have TM1 9.0 SP2
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Re: Extended TM1top
Post by Andy Key »
show75 wrote:I can not end any process execute or object duplicate .
There were issues with some of the early releases of 9 whereby threads showing ObjectDuplicate could hang the server.
I don't have a copy of the 9.0 manuals, so check your documentation to see if ReceiveProgressResponseTimeoutSecs is available as a tm1s.cfg parameter and if so, set it to a reasonable value, say 20 or 30 seconds.
Once your server gets into the situation where one of these threads occurs, after the 20 or 30 seconds the thread will get disconnected and all other waiting threads will resume.
The client who created the sticking thread will have to crash their session, as the client end of the thread doesn't realise that it has been disconnected and will continue to wait.
Andy Key
Kyro
Excel Version: 365
Re: Extended TM1top
Post by Kyro »
Hey,
Just an FYI on this one, The TM1 Top Windows Desktop application has been replace by:
  • Windows Desktop Application - by Ricky Marwan. See Here
  • TM1 Monitor in the Cloud - See Here
Kind Regards,
Ben
