I have created an Action Button which runs a TI process to copy data from one scenario to another scenario for multiple cubes
The TI process runs multiple ExecuteProcess commands and has been working successfully in production for several months
The user community would like to take ownership of this process, thus the need to add an Action Button within the primary Forecast workbook
The Action Button simply points to a cell which correlates to a defined parameter in the TI process
Pretty basic stuff here...
Anyhow, the TI process seems to be running successfully but I get this strange error message while it is processing...
"Completing controls will not fit on the sheet. Please move the control. procedure of process ..."
Another dialog box opens that says...
Completing error %'s
Then the TI process completes and says "Process has completed successfully"
Has anyone ever encountered these error messages?
TM1 Version 9.5.1 with no hotfixes, Excel 2007
Any ideas would be greatly appreciated
Solanna
Action Button Error Message with No Error
Re: Action Button Error Message with No Error
Haven't done a pile with ABs as I consider them rather crippled, but would this be relevant?
http://www.tm1forum.com/viewtopic.php?f=18&t=4626
Solanna
- Version: 9.5.2 to 10.2
- Excel Version: 2007 - 2013
Hi David,
Thanks but no thanks
The Action button works and seems to successfully run the TI process
I just want to know what the messages mean while I'm running it
And I'm certainly not going backwards to Excel 2003
I finally installed 9.5.2 on our Dev Server today since the users are screaming for Excel 2010
Once I get their data onto the Dev Server I'll test the Action Button with 9.5.2 and Excel 2010 to see if I get the same bizarre messages
Thanks for the effort though...
Solanna
Solanna
Andy Key
- Version: 2.5 to PA
- Excel Version: Lots
I've always assumed that the only thing that those messages mean is that there is a bug in TM1 such that it isn't passing the correct arguments to the function that displays the TI Process progress dialog box. I don't consider them to be actually telling me about errors in my TIs. (What? Errors in my TIs? Surely not!
I've seen the 'error %s' one fairly frequently, and the one about controls only more recently, but they are only showing up when I would expect there to be a message box showing me the progress of a TI process. If you take the 'Completing' from the start of the message and the the 'procedure of process' from the end, then take your pick of Prolog, Metadata, Data or Epilog to go between them and add a TI process name to the end, then they start to make sense.
Unfortunately the only idea I've got to get round the dubious messages is to get the users to run the process via TM1 Web, as they won't see the intermediate messages, only the one saying Process Completed Successfully!
Andy Key
Solanna
Andy,
Thanks for the response...
As usual my questions are typically to just get validations on issues that other users have also encountered...
There are so many of these "fake" error messages within perspectives that I'm starting to think IBM Cognos is secretly breaking the product so that the user does not use the spreadsheet anymore! HA!
However, it's going to take more than a few error messages to stop me...
Solanna
Solanna
- rkaif
- Version: 9.1 or later
Apparently this error has been identified as a bug in version 9.5.x in the TI interface and has been fixed in the TM1 10.1 version.
See this URL for details: http://www-01.ibm.com/support/docview.w ... wg1PM32962
- Action Button Error
- ActionButtonErr.JPG (12.64 KiB) Viewed 8895 times
Cheers!
Rizwan Kaif
Rizwan Kaif
- Olivier
- Version: Tm1 10.2.2fp4 -> 2.09
- Excel Version: Excel 2013 - 2019
I have this issue with my action button attached to Tis in 9.4MR1FP3 as well.Apparently this error has been identified as a bug in version 9.5.x in the TI interface and has been fixed in the TM1 10.1 version.
HTH
Olivier
Olivier
