Server List Empty
Jessy
Version: 9.4.1
Server List Empty
Post by Jessy »
Dear All,
I'm coming for help. ;)
I tried to access the TM1 server on the server machine but failed. The server list is empty, although I have configured admin host and refresh available servers time and again.
BTW, I can ping through to the server machine.
Really confused. :?
Waiting for any comments. Thanks in advance!
Re: Server List Empty
Jessy wrote:Dear All,
Really confused. :?
In your client options, are you specifying the name of the admin host by server name, or by IP address? Whichever one it is, try using the opposite one.
Martin Ryan
Post by Martin Ryan »
Also check the firewall on the server is allowing the admin host and the TM1 instance through.
Martin
Jodi Ryan Family Lawyer
Jessy
Version: 9.4.1
Post by Jessy »
Martin Ryan wrote:Also check the firewall on the server is allowing the admin host and the TM1 instance through.
Martin
But other collegues in the same network are able to see the server list.
Besides, both the ports for TM1 admin server and TM1 instance are added to the exception list of windows firewall.
Martin
Makes it all the more likely that the problem is with the client-side configuration.
Gregor Koch
OLAP Product: Cognos TM1, CX
Version: 9.0 and up
Excel Version: 2007 and up
Post by Gregor Koch »
Is your client and server on the same version?
Jessy
Version: 9.4.1
Post by Jessy »
Alan Kirk wrote:
Martin
Thanks a bunch, Alan!
But any other special configurations?
Jessy
Version: 9.4.1
Post by Jessy »
Thank you all dear friends.
Problem solved.
It is caused by the antivirus :P just modify the configuration or shut it down.
