Jessy
Posts: 38 Joined: Wed Mar 25, 2009 7:35 am
Version: 9.4.1
Post
by Jessy » Wed Aug 18, 2010 4:41 am
Dear All,
I'm coming for help.
I tried to access the TM1 server on the server machine but failed. The server list is empty, although I have configured admin host and refresh available servers time and again.
BTW, I can ping through to the server machine.
Really confused.
Waiting for any comments. Thanks in advance!
Posts: 6647 Joined: Sun May 11, 2008 2:30 am
Post
by Alan Kirk » Wed Aug 18, 2010 4:49 am
Jessy wrote: Dear All,
Really confused.
In your client options, are you specifying the name of the admin host by server name, or by IP address? Whichever one it is, try using the opposite one.
Martin Ryan
Posts: 1989 Joined: Sat May 10, 2008 9:08 am
Post
by Martin Ryan » Wed Aug 18, 2010 4:58 am
Also check the firewall on the server is allowing the admin host and the TM1 instance through.
Martin
Jodi Ryan Family Lawyer
Jessy
Version: 9.4.1
Post
by Jessy » Wed Aug 18, 2010 5:52 am
Martin Ryan wrote: Also check the firewall on the server is allowing the admin host and the TM1 instance through.
Martin
But other collegues in the same network are able to see the server list.
Besides, both the ports for TM1 admin server and TM1 instance are added to the exception list of windows firewall.
Post
by Alan Kirk » Wed Aug 18, 2010 6:02 am
Jessy wrote: Martin Ryan wrote: Also check the firewall on the server is allowing the admin host and the TM1 instance through.
Martin
Makes it all the more likely that the problem is with the client-side configuration.
Gregor Koch
Posts: 263 Joined: Fri Jun 27, 2008 12:15 am
OLAP Product: Cognos TM1, CX
Version: 9.0 and up
Excel Version: 2007 and up
Post
by Gregor Koch » Wed Aug 18, 2010 6:19 am
Is your client and server on the same version?
Gregor Koch on Wed Aug 18, 2010 6:36 am, edited 1 time in total.
Jessy
Version: 9.4.1
Post
by Jessy » Wed Aug 18, 2010 6:20 am
Alan Kirk wrote: Jessy wrote: Martin Ryan wrote: Also check the firewall on the server is allowing the admin host and the TM1 instance through.
Martin
Thanks a bunch, Alan!
But any other special configurations?
Jessy
Version: 9.4.1
Post
by Jessy » Wed Aug 18, 2010 8:10 am
Thank you all dear friends.
Problem solved.
It is caused by the antivirus
just modify the configuration or shut it down.
