TM1 9.5 tm1p.ini file not found
Toto
Version: 9.5 Build 9.5.00100.2380
Post by Toto »
I just installed 9.5 Perspective Client and so far it works. But now I can not find the tm1p.ini anymore. Is the name in 9.5 different? Or might the installation be wrong?
Thanks a lot,
Toto
Martin Ryan
Re: TM1 9.5 tm1p.ini file not found
Post by Martin Ryan »
Have a search through the Documents and Settings folder. Make sure you've set windows explorer to display (and search for) hidden files.
Why do you want to get to it anyway? It's best left alone, unless you're having problems.
Martin
Jodi Ryan Family Lawyer
Toto wrote:Hello,
Thanks a lot,
Which operating system are you on?
If it's Vista the file will probably be shoved into somewhere like C:\Users\UserName\AppData\Roaming\Cognos\TM1.
Needless to say, that folder and the files in it aren't included in standard searches, though you may, eventually, at some point in the infinite future, find it if you check the "Include Non-indexed, hidden, and system files (might be slow)" (yeah, no kidding...) box in the Advanced search options after the search result has yielded its usual array of irrelevant results.
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Post by rkaif »
When you install TM1, the installation location for the system default version of the Tm1p.ini file
is
%ALLUSERSPROFILES%\Application Data\Applix\TM1\Tm1p.ini.
In most cases, the full path to the Tm1p.ini file is
C:\Documents and Settings\All Users\Application Data\Applix\TM1\Tm1p.ini.
C:\Documents and Settings\user name\ApplicationData\Applix\TM1\Tm1p.ini.
Cheers!
Rizwan Kaif
Martin Ryan wrote:Why do you want to get to it anyway?
For instance, for the 'AdvancedRulesEditor = T' statement.
baraxil
Version: 9.5
Post by baraxil »
the TM1P.INI file should be under the folder
C:\Documents and Settings\<Username>\Application Data\Applix\TM1 and
C:\Documents and Settings\ALL USERS\Application Data\Applix\TM1
Check to change the folder options from.
In explorer "Tools\Folder Options\" , Select View tab, Under "Hidden files and folders" select: "Show hidden files and folders"
Folder options
Folder options
Folder Options.JPG (39.93 KiB) Viewed 7834 times
laenen
Version: 9.5
Post by laenen »
rkaif wrote:When you install TM1, the installation location for the system default version of the Tm1p.ini file
is
2 points I would like to add
1. ALLUSERSPROFILES -- ini file is the default one. If you have TM1 use the ini file in the user profile that is logged in. If they are not logged in then it uses the All Users and copies it.
2. A slightly different method that works on Win 7 as well as XP is to use APPDATA instead of ALLUSERSPROFILES
%APPDATA%\Applix\TM1\Tm1p.ini
