I have problem when i'm trying to upload excell sheets from architect:
"other will not able to view because a network path could not be established"
I have installed .net framework 4.0 whith asp.net and after this i have this problem
Please help
Problem with uploading sheets from architect
Re: Problem with uploading sheets from architect
http://www-01.ibm.com/support/docview.w ... wg21459178
Make sure you put a copy on the tm1 server, you can do this by right-clicking on the applications folder and selecting to add a file then selecting the relevant options (as opposed to the excel toolbar "upload".) Instead of adding it as a reference.
