IF statements in Cognoscenti Insight
Jwreford
OLAP Product: Cognos insight
Version: Insight
Post by Jwreford »
I have been trying to use an IF function in a calculation section but I keep getting a syntax error saying ; missing left parenthesis.
Can anybody help me solve this?
Re: IF statements in Cognoscenti Insight
If you post your code people will be able to tell you what is wrong with it.
kaazimraza
OLAP Product: TM1, SSAS, Power BI
Post by kaazimraza »
Jwreford wrote:Hi,
Can you please post the code you're trying to get working?
Kaz
Jwreford
Version: Insight
Post by Jwreford »
Sorry it would not let me post earlier, here is the code,
if(['ABS ERROR']=0,1,if(&(['ABS ERROR']>0,['FORECAST']=0,(1-['ABS ERROR']/['FORECAST']))
Joe
Jwreford wrote:Hi,
Joe
Try:
['Destination']=N: If ( ['ABS ERROR'] =0, 1, If ( ( ['ABS ERROR'] > 0 ) & ( ['Forecast'] =0 ), 1- ( ['ABS ERROR'] \ ['FORECAST'] ), 0 ) );
You need to fill the 'Destination' part with whatever the destination measure is and the final 0 is just a guess on what you will want the result of the ELSE to be.
Jwreford
Version: Insight
Post by Jwreford »
Hi Declan,
Thanks for the above to look like this
['IM ACC DATA Measures':'ACCURACY %']=N:If;(['ABS ERROR']=0,1,If((['ABS ERROR']>0)&(['Forecast']=0),0,1-(['ABS ERROR']\['FORECAST']));
But I get the message =N:if; missing semicolon
Joe
Jwreford wrote:Hi Declan,
Joe
Not sure where you gained the extra semicolon from but you need to take it out. I also missed a bracket from the end of the code i provided.
['IM ACC DATA Measures':'ACCURACY %']=N:If(['ABS ERROR']=0,1,If((['ABS ERROR']>0)&(['Forecast']=0),0,1-(['ABS ERROR']\['FORECAST'])));
