What are the Pre requisites to learn the TM1?
Posted: Wed Jan 29, 2014 8:26 am
by helpcognos
Hi Friends,
I have bit Knowledge on Report Studio, FM (Relational ), I want to learn the TM1, Please tell me what are the Prerequisites to learn TM1?
Which areas do i need to learn & Focus more to get more Career Opportunities?
Kumar
Re: What are the Pre requisites to learn the TM1?
Posted: Wed Jan 29, 2014 9:23 am
by declanr
Common Sense + TM1 Software + Time
Search the forum for such topics as it seems to get asked fairly regularly and on occasion people do post helpful responses (such as a link to trial software), also check the FAQ.
Posted: Wed Jan 29, 2014 11:54 am
by Tm1andTm1
Declan,
Common sense is not mandatory prerequisites......
Posted: Wed Jan 29, 2014 12:31 pm
by helpcognos
Hi Friends,
I mean, Which technical Knowledge is needed prior to Learn TM1, Does it require any MDX Knowledge to learn?
Many Thanks,
Kumar
Posted: Wed Jan 29, 2014 1:41 pm
by kaazimraza
helpcognos wrote:Hi Friends,
Many Thanks,
Kumar
Hi Kumar,
From a technical point of view, you need to understand how OLAP works, and have an idea about dimensions, cubes or just give a read through to star schema. From a non-tech/functional point of view, if you have studied a finance or accounting course in college, it should be good enough to get you started, with most of the of examples out there.
Other than the above, you need to have the hunger to learn + time + TM1 software.
Posted: Wed Jan 29, 2014 10:43 pm
by nedcpatm1
Check out the prerequisites for IBM TM1 certification, and also web search TM1 developer/admin job descriptions to get some ideas.
Posted: Fri Jan 31, 2014 2:03 pm
by yyi
if you search for the all sparks cube talked about by legends and activate it, you can make any business system come to life
