Unable to execute SQL Query using TI process.
Posted: Fri Jan 24, 2014 4:08 am
by ryan
I am unable to execute SQL Query using TI process.
I would like to insert a row in simple table.
Database: MS SQL Server (Quoted_Identifier is set OFF in MS SQL Server, in order to entertain double quotes)
Table Details:
Element1: SNO (Int)
Element2: ENAME (VChar(10))
Element3: State (vChar(10))
What I want is:
1, 'Ryan', 'Victoria' to be inserted in the Table1
What I have done:
- Established ODBC Connectivity, I have tested and working fine, I could able to retrieve rows from the table to TM1 environment using the ODBC connectivity.
Code @ Data procedure tab (tried two ways):
#1
vSN = 1;
vEN = 'Ryan';
vSt = 'Victoria';
Query = Expand('Insert INTO Table1(SNO,ENAME,State) VALUES(%vSN% , "%vEN%" , "%vSt%")');
ODBCOutput(DSNName,Query);
Error: Error executing SQL query: "INSERT INTO Table1(SNO,ENAME,State) Values( 1.000,"Ryan","Victoria")"
#2
Query = Expand('Insert INTO Table1(SNO,ENAME,State) VALUES(%vSN% | ',' |vEN | ',' | vSt | ')');
Error: Error executing SQL query: "INSERT INTO Table1(SNO,ENAME,State) Values( 1.000,Ryan,Victoria)"
None of the two query are eligible to run MS SQL Server environment as the string values are not enclosed with single quote(which is not possible in TM1). Is there any extra TI function that could turn double quote in to single quote?. Could anyone help me in running this query without fail? I appreciate your help.
Re: Unable to execute SQL Query using TI process.
Posted: Fri Jan 24, 2014 4:38 am
by upali
Use triple quotes
Query = Expand('Insert INTO Table1(SNO,ENAME,State) VALUES(%vSN% | ',' '''|vEN |''' ',' '''| vSt |''' ')');
Posted: Fri Jan 24, 2014 4:52 am
by ryan
upali wrote:Use triple quotes
oops.... not working.
Posted: Mon Jan 27, 2014 4:56 am
by PlanningDev
Concatenate using the char() function in TM1. Also, I dont think you need the expand function here. The variables should resolve unless there is some reason you are dynamically naming the variables.
Char(39) is for a single quote
Something along the lines of
Query = 'Insert INTO Table1(SNO,ENAME,State) VALUES( ' | NumberToString(vSN) | ', ' | CHAR(39) | vEN | CHAR(39) | ' , ' | CHAR(39) | vSt | CHAR(39) | ')';
Posted: Mon Jan 27, 2014 8:38 am
by Michel Zijlema
Please note (without looking more in-depth at your code) that you're putting a lot of quotes after each other: %vSN% | ',' '''|vEN |''' ',' '''| vSt.
Try %vSN% | ', ' | '''|vEN |''' | ', ' | '''| vSt or %vSN% | ', '''|vEN |''', '''| vSt instead.
Michel
