10.2 FP1 Not Opening TM1 Web
Posted: Thu Jan 23, 2014 1:36 pm
by jim wood
Guys,
Since I've patched to FP1 I've been seeing some strange stuff. Firstly when I try to performance muddler from with the web app interface it doesn't recognize that it's installed, even if I install it again. I can however open PM via the local short cut and deploy apps.
The second funny is that TM1 Web won't open. The load screen comes up but it goes no where. When I try to reload I get a JSP error:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: java.lang.NullPointerException
	org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:502)
	org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:430)
	org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
	org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
	com.ibm.cognos.tm1.web.GzipFilter.doFilter(GzipFilter.java:56)
root cause
	com.ibm.cognos.tm1.planning.PlanningApp.extractHostServerInfo(PlanningApp.java:72)
	com.ibm.cognos.tm1.web.pages.ContributorJsp.RegisterApplication(ContributorJsp.java:52)
	com.ibm.cognos.tm1.web.pages.ContributorJsp.onPageLoad(ContributorJsp.java:121)
	com.ibm.cognos.tm1.web.pages.JspPageBase.service(JspPageBase.java:34)
	org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:388)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.35 logs.
I've checked and the TM1 Web link looks good:
 http://machine.domain.com:9510/tm1web/Contributor.jsp
Any ideas why it's not loading guys?
Re: 10.2 FP1 Not Opening TM1 Web
Posted: Thu Jan 23, 2014 2:19 pm
by David Usherwood
We found that after the patch it was necessary to open Cognos Configuration and resave. After that, Web started working.
Posted: Thu Jan 23, 2014 5:24 pm
by jim wood
I just tried that and it didn't work. I have however found as you said that TM1 Web doesn't work. I did however try to save the config before and it failed. I think that's where my problem lies. I may need to reinstall the software and do the save before starting any services,
Posted: Thu Jan 23, 2014 5:34 pm
by tomok
David Usherwood wrote:We found that after the patch it was necessary to open Cognos Configuration and resave. After that, Web started working.
There's also a Tomcat config file you are supposed to delete right after applying the FP, before you launch Cognos Configuration again. Sorry, I don't know the name of the file but the name and location is listed on the IBM web site in the instructions for the FP.
Posted: Thu Jan 23, 2014 6:19 pm
by Wim Gielis
Posted: Thu Jan 23, 2014 10:03 pm
by Olivier
If the issue persists after deletion of the tomcat folder / config file.
Your issue could also be related to "integrated login" and security mode ?
We get a similar web log message when using security mode 2 ( mixed) and calling a view/websheet via url api with 10.2 FP1.
It seems that FP1 has gone backward regarding the use of mixed security mode. ( only mode 1 let you use url api and pass login and password in the url, we do not use CAM so i can't comment on that...).
Hope this helps,
Posted: Fri Jan 24, 2014 5:09 pm
by jim wood
Guys,
I uninstalled 10.2 then reinstalled it. After I reinstalled it I still got an error for Web but the bright side (I think) is that App Web now knows that performance Muddler is installed. I checked out what I think is the TM1 web Tomcat folder (C:\Program Files\ibm\cognos\tm1_64\tomcat\work\Catalina\localhost\tm1web) and it's empty. I don't think it should be empty. Any ideas what I can do about this? I spotted a folder called TM1Web.ga outside of the Tomcat and I was thinking I should copy the contents in. What do you think guys?
Posted: Mon Jan 27, 2014 10:21 pm
by Olivier
Hi Jim,
Did you try to strat up TM1 application server ?
I am guessing some files might be generated form first service start ?
If that helps see below a screenshot of the Tm1Web folder content after FP1 install.
Tm1 Web folder content FP1.png (25.92 KiB) Viewed 15669 times
HTH,
Kind Regards,
Posted: Tue Jan 28, 2014 1:44 am
by jim wood
Thanks Oliver. I'm having to reinstall from scratch as my tinkering has stopped pretty much everything working. I had however already started the the application server and all my services after my last install run. I didn't however install FP1, The next install run I'll do both,
Posted: Thu Mar 13, 2014 9:39 pm
by Jodha
Jim can you post the resolution i am facing same issue after installing TM1 10.2 web i am able to access Application serverurl /Applications but not tm1 web do i need to unistall and install 10.2 again please help.
Posted: Fri Mar 14, 2014 4:11 am
by jim wood
On my 5th install run it worked. I did however on this run make sure all left over folders were deleted.
