We have TM1 web 10.2 running on Windows2008 R2 using IIS
We have had some applications built for us which have a number of text entry fields as well as number and calculated fields.
We can enter numbers in the fields fine, and can enter text in a few fields but as soon as we scroll down the page a bit and try to enter more text it comes up with the following error
Unable to get value of the property 'cells':object is null or undefined
and then the web page locks up. We have to press the BACK button to be able to go back in to the application.
We arent trying to enter complex text, any text will make it do it. If we zoom the page out to 75% or 50% then it does it less as we dont have to scroll so much. It also seems to work fine when using Xcelerator and Excel, it is only the TM1 Web that is the problem.
So it seems as if scrolling down the page causes some sort of problem with the data entry.
This is the same in Ie9 and ie8. Google chrome doesnt like TM1 web at all as the scroll bars disappear.
Anybody seen this before or got any ideas?
thanks
JB
Tm1 Web - unable to get value of the property 'cells'
Re: Tm1 Web - unable to get value of the property 'cells'
Sure, with that TM1 version I got loads of issues iun TM1 Web.jbra wrote:Anybody seen this before or got any ideas?
Try FP1 and see if it's any better.
jbra
- OLAP Product: not sure
- Version: 10.2
thanks for the reply.
by FP1 do you mean Fix Pack or is FP1 somthing else?
Fix Pack 1jbra wrote:thanks for the reply.
It was released a few weeks ago by Big Blue.
