TM1 process Starting from Cognos portal
Motyl
OLAP Product: Cognos
Post by Motyl »
How I can to start TM1 Process from cognos portal?
I have process that will be copy some data from one cube to another, and process must be initialized by then user from cognos portal.
Re: TM1 process Starting from Cognos portal
The deadset easiest way would be to publish a tm1 web report in BI using an html frame or iWidget or whatever IBM are calling it now. Just include an action button to run the process in the websheet and no problem.
