TR0168 Error!!!!!!
aravind.tm1
OLAP Product: Tm1
Version: 10.2 SP1 32-bit
TR0168 Error!!!!!!
Post by aravind.tm1 »
Hello Experts,
I'm facing an error when importing a package from BI to TM1 using Package Connector.
The error says "(TR0168) Turbo Integrator could not open the data source [[REP_201312131233].[companycode].[companycode]], for sample sample Sap cube in Cognos.
Its just not able to connect to the Data Source at all.PLease help me out!!!
Re: TR0168 Error!!!!!!
Have you tried deleting out the temp files?
This error looks similar to what happens when you have some rubbish left over in the temp folder.
aravind.tm1
OLAP Product: Tm1
Hi Declan,
Actually im trying to extract data from cognos framework manager to tm1 environment,
working with Turbo Integrator Connector!!
aravind.tm1 wrote:Hi Declan,
Yes... I got that part. Hence why I suggested clearing out the temp files.
TR errors I believe from memory and educated guess are actually errors with Transformer which the package connector uses (it's also a product in its own right) and the only errors i've really seen occur are those that result from temp files causing conflicts. Can't remember the exact folder extension but I got back to my previous post and recommend you find the folder, delete the temp files and then try again.
aravind.tm1
OLAP Product: Tm1
Yeah i have tried the same after deleting the temp files ,Still i'm getting
the same 'TR0168' Error!!!
