TI Process to creata Dimension
Acc_Moonwalk
Version: 9.4
Post by Acc_Moonwalk »
I am trying to write a TI process to create the dimension as below :
All Codes - is my consolidation Under All codes in need to have C1 till C100 want to do this using TI.
can you please provide the logic for the same.
This is my project requirment
Acc_Moon
Re: TI Process to creata Dimension
Acc_Moonwalk wrote: I am trying to write a TI process to create the dimension as below :
No it isn't. Your project requirement is to read the Request For Assistance Guidelines before posting questions like this. In particular the one that says:
Also, please don't ask very basic questions about how to do things in TurboIntegrator or Rules without at least looking through the relevant functions in the Reference Guide.
Given the fact that (a) You have not shown that you've made even a vague attempt to do this for yourself (where's the code showing where you've at least attempted it?) and (b) your past posts suggest that you should have enough knowledge to do this exceedingly simple task for yourself by now had you applied yourself to learning the necessary skills, the above post has the smell of "I can't be bothered, someone do my work for me; write the code and post it so that I can charge my client for my TM1 skills."
That is NOT what this, or any other, forum is here for.
Acc_Moonwalk wrote:I am trying to write a TI process
Show us your actual codes and you will be helped.
Do not do any effort yourself, and people will not bother helping you. Life can be simple, isn't it?
