Error with Package Connector 32-bit when using TM1 10.2
Posted: Wed Dec 18, 2013 7:01 am
Hi Experts,
I'm facing an error when importing a package from BI to TM1 using Package Connector.
The error says "(TR0168) Turbo Integrator could not open the data source [[Employee expense].[Account].[Account]]",
for a GoSales Analysis cube (sample cube) in Cognos.
Its just not able to connect to the Data Source at all. Tried with various different packages !
I'm using TM1 10.2.1 and Cognos/FM 10.2.1 versions on a 64-bit Windows 2008 R2 enterprise.
My strong feeling is that the Package connector supports a 32-bit system. Correct me if i'm wrong !!!
I've then followed this link http://www-01.ibm.com/support/docview.w ... wg21450433 and http://pic.dhe.ibm.com/infocenter/ctm1/ ... meter.html and have given appropriate parameters in the CFG file, but still of no avail.
But Again... this link http://www-01.ibm.com/support/docview.w ... wg27021976 shows that "Cognos TM1 package connector works with TM1 32 or 64bit. Please note though that it is a 32-bit product and will integrate with 32-bit source libraries/drivers only."
I have done this in the past with TM1 10.1 and it worked alright, somehow not able to do it with 10.2.
Any suggestions/advices ??
