TI Process to call other TI process
gnrlp
OLAP Product: cognos
Post by gnrlp »
Hi everyone.
Is there a way I can create a TI process that call other process?
Example:
Process 1
Process 2
Process 3
And "Final Process" (will call at same time the 3 process above)
I can't use a Chore for this, because I want to use it in Cognos Insight, and there we can't call a Chore, we can execute only TI Process, and I don't want to put 3 buttons to call those 3 process.
Thx in advance.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: TI Process to call other TI process
Post by Michel Zijlema »
gnrlp wrote:Hi everyone.
Example:
Process 1
Process 2
Process 3
Thx in advance.
Have a look at the ExecuteProcess function.
Michel
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
If you cannot use chores, and you want to run them in parallel, then the other option is to execute them via TM1RunTI utility.
Ardian Alikaj
gnrlp
Post by gnrlp »
Thanks Michel Zijlema and Ardi.
As I will have to call it through Cognos Insight, I believe the ExecuteProcess function will solve my problem.
:D
