I have since been told that the use of FSO in place of the Dir function can overcome this issue, but I am not really sure of how to utilize the FSO in the same way as I did the Dir function to do a wildcard file search in the subset directory in my macro. To be honest the FSO does not make much sense to me. Any help would be much appreciated guys.
Sub Macro3()
Dim NewName As String
Dim ws As Worksheet
Dim TM1Element As String
Dim I As Integer
Dim myDim As String
Dim server As String
Dim fullDim As String
Dim folder As String
Dim destination As String
Dim Subset_Path As String
Dim Subset As String
Dim Subset_Less_Extension As String
Dim currWb As Workbook
Dim test As Worksheet
Dim Name As String
destination = "C:\Users\SK\Documents\TM1\V&P\"
server = "gti_dev"
myDim = "Cost Centre"
fullDim = server & ":" & myDim
Subset_Path = "C:\Users\SK\Documents\TM1\Subsets\" & "Shadow*.sub" 'Subset file directory
Subset = Dir(Subset_Path, vbNormal) 'Variable storing Subset name with .Sub file extension
'Check if specified dimension exists
If Run("dimix", server & ":}Dimensions", myDim) = 0 Then
MsgBox "The dimension does not exist on this server"
Exit Sub
End If
Set currWb = ActiveWorkbook
'Loop through all the Subsets in the Subset file directory
While Subset <> ""
Subset_Less_Extension = Left(Subset, Len(Subset) - 4)
NewName = Right(Subset_Less_Extension, Len(Subset_Less_Extension) - 9)
For I = 1 To Run("subsiz", fullDim, Subset_Less_Extension)
TM1Element = Run("SUBNM", fullDim, Subset_Less_Extension, I, "")
'MsgBox TM1Element
currWb.Activate
Range("$O$1").Value = "=SUBNM(""" & fullDim & """, "" & Subset_Less_Extension & "", """ & TM1Element & """, """")"
Application.Run ("TM1RECALC")
' Application.ScreenUpdating = False
If I = 1 Then
Sheets(1).Copy
ActiveWorkbook.SaveAs Filename:=destination & NewName & ".xlsx", FileFormat:= _
xlOpenXMLWorkbook, CreateBackup:=False
Else
Sheets("Budget").Copy After:=Workbooks(NewName & ".xlsx").Sheets(Workbooks(NewName & ".xlsx").Sheets.Count)
End If
'Sheets("template").Copy After:=Workbooks("NewBook").Sheets(Workbooks("NewBook").Sheets.Count)
'If I = 1 Then
'Sheets(1).Copy
'ActiveWorkbook.SaveAs Filename:=destination & Subset_Less_Extension & ".xlsx", FileFormat:= _
'xlOpenXMLWorkbook, CreateBackup:=False
'Else
'Sheets(1).Copy After:=Workbooks(Subset_Less_Extension & ".xlsx").Sheets(1)
'End If
Cells.Copy
Range("a1").Select
Selection.PasteSpecial Paste:=xlValues
Cells.Hyperlinks.Delete
Application.CutCopyMode = False
Cells(1, 1).Select
ActiveSheet.Name = Left(TM1Element, 31)
Application.ScreenUpdating = True
Next I
ActiveWorkbook.Save
ActiveWorkbook.Saved = True
ActiveWorkbook.Close savechanges:=False
'Retrieve the next Subset file in the directory
Subset = Dir
Wend
Set currWb = Nothing
End Sub
