Is there a way to configure in Web.config to have the title in Internet Explorer show something other than the path to the file.
Currently: "Websheet - //MYSERVER/ExcelTemplates/Home.xls - Windows Internet Explorer"
Preferred: "Websheet - Home - Windows Internet Explorer"
Tested in Firefox as well. Path shows on tab.
<!-- If set, the object of type of Websheet, Cubeviewer or Url will be displayed upon user's login. -->
<add key="HomePageObject" value="//MYSERVER/ExcelTemplates/Home.xls;Type=websheet;Description=Home;AllowOverwrite=true" />
TM1Web Websheet - Hide .xls path in browser title
Re: TM1Web Websheet - Hide .xls path in browser title
Never something I've actively tried to do but as a by product of something else I was doing I have found that if you navigate to a websheet using a hyperlink() formula it will display the tab as the "friendly name".
So depending on whether you have a menu sheet and how you wish to navigate to subsequent sheets then that could do the trick for you.
Kingsley
- Version: PA 2.0
I see what you mean but this Home.xls is my default page where it launches automatically when users log into TM1Web.declanr wrote:Never something I've actively tried to do but as a by product of something else I was doing I have found that if you navigate to a websheet using a hyperlink() formula it will display the tab as the "friendly name".
This Websheet then have multiple hyperlinks used to navigate to other Websheets. These sheets show friendly names on the title bar with no problems.
If it's a huge issue you could always go about displaying the pages through a third party tool; such as sharepoint - if I remember correctly that used to cover up the tab names.Kingsley wrote:I see what you mean but this Home.xls is my default page where it launches automatically when users log into TM1Web.
I assume this is just due to you not wanting users to see the link between TM1 Web and it's torrid excel origins?
Kingsley
- Version: PA 2.0
I wouldn't say this is a major issue. I definitely would not go into implementing Sharepoint to this. I personally just think it takes away some of the aesthetics TM1Web offers. I was hoping it would be a simple additional line in the config file. some kind of integreated XML/HTML feature.declanr wrote:If it's a huge issue you could always go about displaying the pages through a third party tool; such as sharepoint - if I remember correctly that used to cover up the tab names.Kingsley wrote:I see what you mean but this Home.xls is my default page where it launches automatically when users log into TM1Web.
ie: <a href="http://www.homepage.com">Click here to go Home</a>
Guess not?
