Dimension Order is greater than 2
Kazêh
Post by Kazêh »
Hello guys, pretty simple question, when you create an aplication in performance modeler and that aplications contains a cube with the wrong orden dimension it send you a warning with the best practiices.
I know you should put first your elist dimension and your measure dimension last, this time i created a cube with the wrong order dimension, i forgot to put the elist first.so to correct this warning i press rigth click on the cube and used de order dimension option,but the warring still appears, and sometimes doesnt let you change the order, so normaly i recreate the cube with the same name and chose the riight order.
What i wanted to know was if there is other way to correct this without reacreating the cube?.
does the order diimension option works for this?
someone has experience with this warning?
If anyone knows anything please let me know,
thanks for any tips
Kazeh ;)
Re: Dimension Order is greater than 2
I usually ignore that warning straight away.
